ZTE has unveiled two versions of the Nubia Z9 at a press event in Beijing. Meet the Nubia Z9 mini and Nubia Z9 Max.
ZTE Nubia Z9
The ZTE Nubia Z9 Max is a phablet, powered by the Snapdragon 810 chipset, 3GB of RAM and comes with 16GB of internal storage. Supplying juice to all these components is a 2,900mAh battery. The Nubia Z9 mini by ZTE is a mid-range smartphone, sporting the Snapdragon 615, 2GB of RAM and 16GB of internal storage (with microSD support). The same battery is fitted to the mini.
ZTE Nubia Z9
Both handsets pack a 16MP shooter with support for 4K video recording. The 8MP front-facing camera is all set and ready to go for the ultimate selfies. Android Lollipop 5.0.2 comes pre-installed. The looks of both devices are pleasing with a metal frame wrapping around the sides. If you're into replacing back panels, you'll want to go with the mini as the Nubia Z9 Max comes with an all-glass rear.
You can also expect to see LTE support included inside the Z9 Max and mini. The former phablet will require you to part with CNY2,499 ($400), while the Nubia Z9 mini costs CNY1,499 ($240)
Source: Anzhuo, ZTE
