Seidio extended battery
Now that is a whole lotta juice
Your Galaxy Note 3 already has a healthy 3200mAh battery, but for some folks that's just not enough. The large screen is perfect for watching video on the go or playing games, and everyone knows that watching video over the cell network and playing games is h-e-double-hockey-sticks on a smartphone battery. Seidio has a product that might be able to alleviate a lot of the issues — their 4800mAh battery for the Note 3.
It makes your Note 3 a little thicker, but with approximately 50 percent more battery life and NFC capabilities, it's a trade a lot of us will be willing to make. Have a look and see if that sounds like you.
thick
Right off the bat, know that this thing is much thicker than your stock Note 3 is. With the included extended battery door installed, you're looking at just about a half-inch in thickness. This tapers at the top and bottom, but your Note 3 is going to get a little thick and juicy. OK, maybe not juicy. But thick. And that makes a difference in how the Note 3 "handles." Part of what makes the Note 3 fairly easy to use is the fact that it is so thin at .3-inches, and when you double that, you can tell the difference.
But the trade off seems worth it. While I haven't dug out the multimeter and amp meter, I've been using the battery for a bit. The Note 3, with this battery, is a two day device — you only need to charge it every other day with normal use. Movies, or multi-hour sessions of BTD 5 barely put a dent in it, and you will notice a difference no matter how you use it.
Another cool thing is that NFC still works, as it's baked into the Innocell. While the lack of NFC on a smartphone never hurt anyone, having it there — as it was designed to be — is always a plus. For those who love to use tags to do routine tasks, or share media with other NFC-enabled Androids, you'll be able to do it just like always. I did not test ISIS, as there are no places to use it within a million or so miles from me.
The battery cover is pretty basic, and pretty glossy. It comes in black or white — I'm doing the panda thing here with a white Note 3 and a black cover — and fits right over the extended battery. Because it's super-glossy, you'll get fingerprints all over it. This doesn't affect anything, but if fingerprints make your OCD get fired up, know in advance that you'll see them. Lots of them. A quick wipe on your shirt takes care of most of them, though.
Overall, I think the Innocell 4800mAh battery is not for everyone. Normal users who have their phone off and in a purse or pocket most of the time just don't need the bump at the expense of the hump. But if you're the type who always has the screen on, this one is for you. You treat your phone as a tool, and if that tool needs to be a half-inch thick, so be it. You need the juice, the Innocell has the juice.
Reader comments
Seidio Innocell 4800mAh battery for the Samsung Galaxy Note 3
40 Comments
Any pricing? Didn't see it in the article
I love my case, but this could be a good extra battery for trips
You really should see the crap I don't post. Sorry if honesty offends you
It is, thanks
This is a great low profile option but if you're looking for a marathon battery that will last almost a week then the Zero lemon 10000 mAh is a better option because the battery cover is a tpu case that protects the phone and has a much higher capacity and is much cheaper.
Why do these companies think we want a shiny slippery finger print magnet of a back cover...I don't get it.
Ive never had luck with these batteries. Had 2 of them for the nexus and they went bad within a month. I wasnt getting anywhere near as much juice as I should out of them in a short amount of time.
Actually it's not that bad when you see it in person. I have this battery plus the Seidio case and holster. Makes the phone pretty easy to handle.
Am always interested in extended battery life but worry the case is not protective enough. I use my phone for work and am often outdoors. Working with animals I have had my phone knocked out of my hand on occasion. Any input from users?
Get the ZeroLemon extended battery. It's more than twice as big and has a case built into the battery cover. It's also cheaper! Still high quality tho. I have their note 2 battery. You can find it on amazon.
+1 unless you are out all day
My Note 3 charges pretty quickly too. I don't want to give up the thin factor, for the battery thickness and extra juice. I also like the leather like back cover .... the glossy slippery back is no fun.
I'm going for the ZeroLemon LG G2 3500mA extended battery case.
Posted via my SPARK enabled Sprint LG G2.
I have the 9300 mAh battery for my Note 2. I can barely make two days...by that I mean at the end of the second day I'm at less than 15%. Although 15% on that battery is way more than 15% on a standard battery. I dunno if I have insane wake locks or what, but I can't get the 3-4 days some people claim...just doesn't happen. I do use my phone a /lot/ tho...
Verizon? If so.. battery life on The VZW Note II went down the toilet after the first OTA.. don't know why or how but it did.
Well... hmm why buy this when you can get zero lemon battery which is 10,000mAh and lasts me 3 days on single charge with extremely heavy usage. Just don't see the logic behind sedio battery.
I buy Mugen now. Seidio would not replace a batter cover that was bad and failed after a few months.
