Samsung Gear S3 Frontier and Gear S3 Classic specs
Samsung's Gear S3 Frontier and Classic are notably larger than their predecessors, but that means they hold improved specs, larger displays and perhaps most importantly a bigger battery. Though the specs aren't groundbreaking, the fact that they all fit in a smartwatch size is pretty impressive, and the Gear S3 Frontier and Classic make it look good as well. Here's the full spec list:
Swipe to scroll horizontally
CategoryGear S3 Frontier and Classic
Screen size1.3-inch circular AMOLED360x360 resolution, 278 ppiCorning Gorilla Glass SR+
ProcessorDual-core 1GHz Samsung Exynos
RAM768MB
Storage4GB
Operating systemTizen Wearable OS 2.3.2
Battery380 mAh
ConnectivityBluetooth, Wi-Fi, GPS, NFC, MSTLTE optional (Frontier)
ResistanceIP68MIL-STD 810G (Frontier)
Case size46 mm
Band size22 mm
Dimensions46 x 49 x 12.9 mm, 62 g (Frontier)46 x 49 x 12.9 mm, 57 g (Classic)
Andrew Martonik
Andrew was an Executive Editor, U.S. at Android Central between 2012 and 2020.
