Samsung Level Overs versus Beats Studio Wireless
Comparing the high-end cans from the names you know
I have a weird fetish for headphones. I have a handful of sets of my own, ranging from ones I spent too much money on to ones that were cheap but sound surprisingly good. Recently, Samsung sent me a sampling of their new Level Audio gear, and I just knew we had to compare the top-of-the-line Level Over headphones to a set from another company familiar to everyone interested in mobile — Apple's Beats Studio Wireless.
While neither of these headphones are going to suit the serious audiophile (or anyone who likes to play one on the Internet), I can't lie and say either is a bad purchase. Yes, if you came to knock either or both brands and are looking for someone to validate that, you didn't find the right place. Both companies have built headphones designed to be driven by something small — like a smartphone — and they each have their own unique sound. There's a very good chance that you'll really enjoy the sound from either of these headphones, so let's take a look and put them head to head in the categories that matter.
Construction, design and features
Samsung Level Over
Samsung has stuck to the basics with the Level Over design. The white and tan model could easily have looked gaudy and over the top, but the combination of quality materials and craftsmanship give them a very understated beauty. You instantly get the feeling that you're using a premium product when you first open the box and put them on. While they're constructed mostly of plastic — like most all headphones — the finish and fit is excellent. We should expect this (and more) from a $350 pair of headphones.
The headband is a faux leather with an attractive cross-stitch pattern. There's a generous amount of padding on both the headband and the closed-back ear pads themselves, and you'll appreciate this with any prolonged use. The headband is adjustable, and will fit most everyone, and the Level Overs fit nicely into their supplied carrying case, though it is a bit large. Hopefully the next version will fold to save some space.
On the left-side ear pad, you'll find the USB port to charge the built-in battery, and an NFC tag for easy pairing with any NFC-equipped Android device. On the right ear pad you'll find a 3.5mm jack for the wired connection, a status light and the power switch. There's also a button that can toggle the noice cancelling or initiate Bluetooth pairing. Both earpads have small microphones used both for taking voice calls and part of the active noise-cancelling features. One of the coolest features is on the right-side ear cup — a touch sensitive control pad that lets you swipe forwards or back to change tracks, or tap the center to play or pause playback while you're connected via Bluetooth.
The Level Over headphones will connect via Bluetooth 3.0 and include apt-X technology for "lossless" audio over a wireless connection. Of course, as a Bluetooth headset they also work with Voice Actions or Samsung's S Voice.
Beats headphones have their own iconic, great look, and the latest Studio model hasn't changed too much. They have been slightly redesigned so that they aren't as wide as previous models, and this doesn't seem to sacrifice any audio quality. When you see a pair of the new model Beats Studios Wireless, you still know you're seeing Beats high-end at it's finest. The matte black model I'm using for this comparison look especially nice. Besides looking good, they also are extremely well-crafted and feel like a $350 pair of headphones should feel.
The synthetic leather used in the headband and ear cups is soft and supple, with plenty of padding. The ear cups are the standard closed back design you would expect from a pair of Beats headphones, and everything feels very nicely built. The adjustment is more than adequate to fit just about everyone, and the tri-fold design fits them neatly into the included carrying case.
The right ear pad has the single power button, a micro USB connector to charge the internal battery, and a handy set of LEDs that act as a battery fuel gauge and pairing indicator lights. The power button can also enable active noise cancellation without audio playback if you just want to use them to tone down some outside noise. The left earpad has a 3.5mm jack for a wired connection, and the "b" logo acts as a mute button to stop audio playback and disengage the active noise cancelling while it's held in.
The Beats Studio model also connects to your smartphone via Bluetooth 3.0 with apt-x, and act as a standard Bluetooth speakerphone with access to voice actions, but I had issues getting S Voice on my Note 3 to work until I headed into the forums and found a solution. It's worth noting that Siri works, but you need to start Siri via the button on your iPhone.
Beats scores
The first round goes to the Beats. Both pairs of headphones are extremely well built using grade-A materials. Both have plenty of features, some you didn't even know you wanted or needed until you used them — like a set of LEDs that acts as a battery gauge. And the matte finish on the Beats pair just puts it over the edge. I had to think about this one, because the touch controls on the Level Overs were a very nice addition. But knowing if I need to charge before I leave the house is more important in the long run.
Comfort and usability
Samsung Level Over
The Samsung Level Over cans are some of the most comfortable headphones I've ever used. They hold in place well, but don't squeeze your head too tightly. The pleather covering of the ear cups and headband can get a little sweaty, but they seem to wick away some of the moisture and don't get slick and nasty. You'll be able to wear the Level Overs all day without any sore spots or headaches.
Speaking of all day, the Level Over headphones have decent battery life. With noise cancelling active, you'll get about 10-12 hours of use over a wireless connection. With noise cancelling turned off, you can double that. I prefer to use the built-in passive noise cancelling that a pair of solid-back headphones offers, and was very satisfied with the battery life from the Level Overs. Of course, over a wire they last forever.
The controls work as expected, especially once you've installed the Samsung Level companion app. Calls sound just like they would on any other good Bluetooth headset — a little robotic and distant. I could use the Level Overs on a long trip and have zero issues. The controls on the cord work with Android (and Windows Phone and every phone not made by Apple) as you would expect.
I found the new model Beats Studios a little uncomfortable to wear. They offer plenty of padding, but they tend to squeeze my melon a little more than I would like. This could be perfect if someone wanted to use them while exercising, but when reclined in a chair and listening to some music I had to remove them after a few hours. I have plenty of hair and a big head, so this may be a non-issue for you.
Battery life was excellent, and over Bluetooth you'll be able to use the Beats Studios for about 15 hours with audio playing. I would estimate that a full charge would last for several days in noise cancelling mode without any audio connection — I gave up after 12 hours and still had a "full" charge on the battery meter LEDs. Unfortunately, you can't use the Studios over a wire unless they are charged. The good news is that the battery also seems to last forever when used this way.
As a Bluetooth headset, all the basic functions work fine. Calls sound as good as they did on the Level Overs, and basic voice actions (OK Google) worked when Google Search was set to accept commands over Bluetooth. S Voice was more hit or miss, but worked fiarly well using this tutorial from Hghlndr in the AC forums. Thanks, Hghlndr! It's not surprising, but the in-line controls only work with Apple products. There's some science here — Apple switches the positioning of a 220 Ohm and 600 Ohm resistor so that they need a different set of controls. Think Different.
Samsung scores
Samsung wins this round. The Level Overs are simply more comfortable to wear. Both sets of headphones worked as expected, and fit snugly enough to stay in place, but the Beats Studios were just a bit too tight for my liking. If you have a large head — or even worse a small hoop earring or two — think about how this could affect you.
The real deciding factor was the ability to use the Level Overs (with no noise cancelling) while the battery is dead via the cable. You might hate using a cable with your headphones, but you probably hate not being able to use them at all even more.
Sound quality
This is what it all comes down to, right? Each of the models here deliver excellent sound in their own way. No, it's not the "flat" sound you would expect from a pair of studio monitors, but consumer-grade audio equipment is rarely designed to deliver that. Both Samsung and Apple's new engineers have tuned the sound to provide a gentle curve in the hopes that the target audience — that's you and me! — will enjoy what they've done.
Samsung Level Over
I'll be upfront about it — I like the sound from the Level Overs. It feels like Samsung has tuned the audio fairly close to how I would tune the EQ on my stereo when listening with my Sony monitors. That's going to bring a little bias into this showdown, but I can't help that.
As a reference for testing, I used some lossless FLAC files, and played the audio through Poweramp. All testing was done on an LG G3 to keep any special Samsung or iPhone tweaks out of the picture.
I found the Level Overs to deliver great (read: excellent!) mid-range sound. You can hear each instrument clearly, and vocals were great. The high-end sounds (think a cymbal crash or high-pitched lead guitar) were a little off, but not muddled or distorted. There is a bit more bass than I care for, but it's not at an unacceptable level. It's close when listening to 1980's progressive rock music, but things sound much better when listening to something like a RUN DMC track where you want a bit of kick in your bass.
The Level Overs sound best over a cable, but Bluetooth audio was also very nice. They have been designed so that even a small source like your smartphone can deliver big sound, and you'll have no problems driving them from just about any source. Active noise cancelling produced a barely noticeable hiss between tracks, but nothing that was audible to me while music was playing.
While the Beats Studio cans weren't able to deliver quite the sound I'm looking for with the music I like to listen to, I can't say they sounded bad at all. The DSP has been retuned with the new model to kill some of the overbearing bass, and when listening to certain tracks — Billie Jean by Michael Jackson is a great example — they sound as good or better than the Level Overs.
Your mids sound great as long as the music you're listening to doesn't have a lot of deep bass, and the highs actually sound a bit better than the Level Overs when you can hear them on their own. The real difference is with the bass sounds. Beats still emphasises them a lot, and they can overpower everything else if the music you're listening to runs the full range from 20Hz to 20KHz. For some kinds of music, this is not a good sound. For others it is. With music like Hip Hop or some serious Funk, it's awesome. Grandmaster Flash and Melle Mel have never sounded better. Just don't try to listen to the Philadelphia Orchestra through them, because it doesn't sound very good.
Like the Level Overs, sound was also very good over Bluetooth. Apt-X is a fickle beast, but the combo of the LG G3 and Beats Studios (as well as the Samsungs) work well, and while I still say a wired connection sounds better, Bluetooth was rich and full with no static or crumbling that you'll find with older equipment.
There is one huge issue with the Beats Studios, and I found it to be the same no matter the source. The active noise cancelling produces one hell of a hiss. You'll hear it between tracks (that's not uncommon) but you'll also hear it while you're listening to some music unless you have the volume at about 50% or higher. When I'm kicked back in my Lay-Z-Boy chilling to some soft music, I do not want to hear a hiss over the top of every note. For me, this makes the Beats Studios a non-starter.
Samsung scores
That hiss. There's nothing I can say to make it any better and I'm not going to sugar-coat anything when talking about an expensive set of headphones. I can't deal with it and the Level Overs are the clear winner in audio quality because of it.
The final verdict
Samsung Level Over
Most of the things we talk about when we say audio quality are based on preferences. You may not like the same sort of music that I do, and the full-on bass from the Beats cans may be exactly what you're looking for. I'm no audio snob, and there were plenty of songs that I loved hearing through the Studios, as long as I had the volume cranked up so that things didn't hiss.
But when it comes down to comfort and the active noise cancellation feature, the Samsungs are simply the better choice. They feel better when wearing them, and have none of the issues Beats has with ANC hiss. If you listen to a lot of music, you'll appreciate both of these points.
Would I buy or recommend them? To me, the Samsung Level Overs offer great full sound without any EQ fiddling. I love they way they sound when using them with my smartphone, and the full day battery life fits right in with a full-day of comfortable wearing. They aren't audiophile-perfect by any means, but if you want to buy a premium set of headphones and expect premium sound, I say they are a great purchase. I'd love to have a pair of my own for my gear bag because they sound so good out of the box with my phone.
Reader comments
Head to Headphones: Samsung Level Over vs. Beats Studio Wireless
62 Comments
Very Spooky, ive been researching headphones over the past hour, and then my favourite site AC does a segment on two of the top selling headphones....
Very cool, thanks Jerry, i think i'm ready to discount the beats ones totally now.
I would recommend looking into the Sennheiser 380 Pro, which can be found at a great price online and price matched is stores. At least, that is what I did recently. I would also recommend looking into Grado if you don't mind a pair of open ear cans.
I am a "Soul" lover of the Soul headphones I have compared them to Beats and I like the comfort, sound quality, and design of the Soul over the Beats. The Beats though do have the best colors.
~My $0.02~
It will be my very first over the ears headphones for me from Samsung for my Galaxy Note 4.
This purchase makes since to go along with the Galaxy Gear 2 Solo and the Galaxy Tab S 8.4 LTE tablet all on October 3rd.
It's pretty plain and simple nothing beats Samsung or the Galaxy Note products period they are Android nothing else matters.
From my Galaxy Note 3 on T-Mobile via Android Central App
ELP! I grew up listening to them. The drummer used to be my idol till' Mike Portnoy of Dream Theater filled the void!
Used them for a bit at Guitar Center. If I'm paying that much for cans, they can't have that much bass and need a way to shut off the surround. Would be very interested in hearing them from a phone or iPod though, where you have less control and rely on the design for tuning that sounds nice.
Still haven't found anything I like better than my Sony 7506's for listening at home from a receiver. But I will keep looking :P
Another Sony man, the truth stays in the ear cups.
My 4 year old daily drivers (Sony MDR-XB500) thank you.
Posted via t he Sprint LG G2 Android Central App
Jerry, I have never heard anyone else actually make any mention of the bass being too much with these headphones. I applaud you sir. That's the very reason I will not buy any myself.
Great write up Jerry. Thanks!
I just got a pair of the Level On for free yesterday and was super impressed by the sound.
I think I might give those to my ol lady and pick up some Level Over now! They seem to be pretty legit.
I bought the level overs in black the day they came out at best buy. I have to say that I am very impressed with Samsung on these. The sound quality is excellent and the noise canceling is great as well. The level over software is a must have though...it adds a bunch more functionality and even has a setting for listening fatigue (auto adjusts the volume when you are listening at max volume for long periods of time)
My verdict: well done on these premium headphones. I like them better than the bose bluetooth headphones my wife has.
I have a pair of Level In which i got as a gift. I can genuinely say it is better than bose earphones. I love them. Kudos Sammy
And apple paid what for these? I know it was for the other services they will inherit.
from my old note3 which i had to sell my soul for;)
I'm not surprised at all. Beats has always put looks above everything else and I still find them to be highly overrated. Though I doubt I'd pay that much for Samsung's version either. But if they went on sale...
Got Sennheiser HD202s for $20. Downside is they don't fold. Sound good to me. Had HD280s before that.
Paying for design is silly.
To each their own but you are basically comparing apples to oranges here. Yes they are both headphones but the ones being compared here are wireless bluetooth headphones with noise canceling and app support. The sennheiser headphones you are comparing are basic in nature. Almost like saying my $9 skullcandy ear buds sound fine.
Good thing sound is an opinion.
Those seinheisers are very basic sounding, just like their price tag suggests.
Don't get me wrong, I'm glad you like them! However, the comment above is right in that it is apples to oranges. You are mentioning an entirely different level of headphone.
I'm not sure what "basic sounding" means. Seems kind of vague to me.
They seem to be a good all-around headphone for me. I listen to a variety of stuff and no way am I going to carry a different set for each type of music.
Hardly. The Sennheiser cans sound better than the 300$ Beats. They aren't on the same price point...THAT WAS THE POINT
Glad someone understands.
It's about sound, after all. Bluetooth and a fancy design do not substitute for audio quality.
I love ATH-M50s, AMAZING bang for the buck. As with all AT cans they have a held back mid sound signature, but that's just Audio Technicas sound signature. VModa M100s are for bassheads, very clean highs and TIGHT lows.
I have ath m-50 as well as ath m- 35. I love ath m35 rather than m-50 for portable music player... There is a slight improvement of sound in m-50 but that's just very slight but the price is almost double. And ath-m35 has better comfort over the head and ears.
this! I've been looking to buy some good quality headphones and I finally went with these. I was blown away with the sound quality and they only cost me 120.
it shocks me that people spend 300+ for beats when there are much better headphones for half the price
True!! Beats products are all about style. They're for show. No audiophile or even music lover that does their research would buy Beats.
I remember the first time I tried a pair on, a friend was bragging about how awesome they were. They felt nice and sounded pretty good, then he told me they were $250 and I laughed.
You're paying for the b on the side.
if "this is what it comes down to, right?" as a measuring stick, neither Samsung or Beats should be reviewed in this article. There are other brands I'm sure casual listeners would know of, such as Sennheiser/Audio Technica, to brands that are not as well known to average consumers such as AKG and BeyerDynamic.
These 2 brands that are being mentioned are still fashion accessory type of headphones, at best. Just my opinion only.
I can agree.
But I actually think one of the best headphones I have tried (which I own) I the Sol Republic Master Tracks. Anything lower than that from them sucks. V10, V8... All crap haha.
But the master tracks.... Very good.
I compared an Audio Technica (which I like a lot) to this one and this one I preferred. Especially at the price point.
Wonder what Jerry thinks of these.
I've not seen Bose get a mention in either the article or these comments, good as rather they didn't sell out either...
Everybody knows Beats are overhyped. They are too bassy and don't offer an overall tonal quality. They are just about standing out and costing too much.
Don't waste your money on either of the headphones. Those two brands are worth $35 at the very most. Stick to Bose, Klipsch or Sennheiser.
Only buy Beats or that ridiculously named Samsung if you're a brand junkie and MUST be seen with the latest popculture brand.
+1 hell no im going to spend so much money on it..
I could understand you want to spend money on good gear when you are a music fan, but from what I've heard you can get equal or even better headphones for a lower price.
Posted with the speed of my G3
BOSE, Klipsch and Sennheiser are ALL over priced...and I'm sorry, that last time I checked the 3 mentioned brands are...well....brands.
Do the level over work with Google now? I mean stock nexus voice features?
I just got new Beats Sudio Wireless as a gift, on the box it says For IPhone, Ipad, ipod ?
Will they work with my Samsung Galaxy S5 phone???
Hello Jerry Hildenbrand,
thanks you for the comparison. I am also a bit obsessed with Headphones, well, with finding the best Bluetooth Headphone (which is still portable enough).
I compared lot of them.
I have a question about the Beats Studio Wireless: are you SURE that they support APTX?
There is no mention to APTX in their website, nor in the Quickstart Guide (which is the ONLY document for them. There is no manual! Or did you find one?).
In internet I had read about them having APTX, so I bought them.
But when they connect with my APTX enabled Phone or my APTX enabled Notebook, there is NO message about "connection with an APTX device":
With all my other APTX devices there is/was. ALWAYS.
I am aware that for example the Sony MDR-10RBT (which I also tried) come with the standard mode enabled, and if you want the APTX you must enable it with a combination of keys.
But here, nowhere is to find any info about how to eventually activate the APTX IF they really have it.
Any help???
Thanks!
I have tried them both.
The Beats are very beautiful but sound muddy on the basses (which are exaggerated and dark and dull) and harsh on the highs, and poor on the mids.
They have excellent range, the best I have tried till now. No dead spots in my little House.
They are anyway NOT Aptx like Beats say to everybody at the telephone (I even have this answer in an email). I find it a real SHAME for Beats, spreading such a false information! I will never trust this company anymore till they will not make an official declaration about this as a mistake.
The Samsung are HUGE, the less portable Bluetooth Headphones I have ever seen.
They have a very cool (HUGE) rigid carrying case, they look nice, have nice touch controls, and sound DECENT.
The soundstage is good, the details also. The basses are almost non existing, the mids are good, the highs are just ok.
Their ANC is very good on the low frequencies, not so on the highs.
They have an extremely annoying problem: EACH time you turn them on you must adjust their volume. They do not remember the last setting. And their volume is not affecting the Bluetooth Volume of your Handy/PC/etc, it is independent.
They are NOT loud. To get the same loudness which I got at 60 with the Beats, I had to set the Samsung at 80 or more. BAD.
They are very comfortable.
It's hard to believe anyone would buy either of these sets of cans when you can often pick up SennHD600s or HD650s for the same $350!
If we're talking sound quality, the Sennheisers are true audiophile level headphones, while the ones in this article are fashion statementsfor those not concerned with audio quality..
