I had been resistant to put a case on my Nexus One because I could never find one that I was happy with. They were always either too bulky or felt too cheap.
Having said that, I have been very pleased with the Case-Mate Tough Case; it does not weigh the phone down at all and feels very robust to the touch.
The outer-layer of the case is an ABS plastic shell that has enhanced dust protection. The phone slips inside a smaller rubber skin that then fits inside the tougher case. All buttons and and ports can be accessed without hindrance.
The screen is not covered, but it is protected by the rugged outer layer of the case, so don’t worry if you leave it upside down.
The case also comes in four different colors: black, pink, green and blue, so everybody should be able to find something that fits their lifestyle.
The Case-Mate Tough Case is available for $27.95 from the Android Central Store. More pictures after the break.
82(forum posts)
