Setting up an LED light strip behind your TV or computer can seriously enhance your binge-watching or gaming experience, and they're super easy to install too. Today you can even pick one up by Minger for as low as $6.99 at Amazon using the appropriate promo code at checkout. That's an insanely low price for something that you'll likely benefit from on a daily basis.
So Many Colors
Minger 6.5-foot RGB Light Strip
Using code DC4SZQ3V will save you 50% off this RGB light strip that comes with an IR remote allowing you to change light modes, colors, brightness and more easily. There's also a 3M adhesive backing which makes it easy to install nearly anywhere.
$6.99 $13.99 $7 off
Smart Buy
Minger 16.4-foot Smart RGB Light Strip
This RGB light strip lets you control it completely using an app on your phone. It has tons more color options than the model above too, but you'll need to use code JR7EJ2UA to score it for this low.
$17.99 $29.99 $12 off
The most affordable option you can snag right now is this 6.5-foot RGB Light Strip. Using code DC4SZQ3V during checkout will bring its price down to only $6.99 from its regular cost of $14. It comes with an IR remote so you can switch its color, brightness, and more, while the back of the strip features a 3M adhesive backing which helps you easily stick the strip wherever you'd like.
Verizon is offering the Pixel 4a for just $10/mo on new Unlimited lines
If you're looking for a smart light strip that you can control using your phone, then the next option is the one for you. This 16.4-foot Smart RGB Light Strip drops to just $17.99 when you enter promo code JR7EJ2UA during checkout, saving you 40% off its regular cost of $30. I actually picked this model up myself just a few weeks ago, and it not only lives up to its claims on Amazon but it's also a bit more durable than you'd expect for this price. The Govee Home app lets you change its color and brightness, switch light modes, schedule on and off times, and more. It's even capable of syncing to the beat of your music, but that's a feature I believe could use a bit more fine-tuning. It can even be voice controlled using a device like the Echo Dot or Google Home Mini. In any case, this version is easily worth its full price, and getting to snag it at 40% off is a steal.
We may earn a commission for purchases using our links. Learn more.
