The Luminoodle Click Light Strip three-pack is currently down to just $29.99 at Woot. This deal allows you to choose between cool or warm white light strips and includes free shipping for Amazon Prime members. Over at Amazon these lights regularly sell for $40, while a single light strip would cost $20, although both have on-page coupons for 20% off right now.
Illuminating
Luminoodle Click Light Strip, 3-pack
These battery-powered LED strips are super-easy to install anywhere you need a little extra light. They're 25% off at Woot for a limited time, so it'd be a bright idea to get your order in while you can.
$29.99 $39.99 $10 off
Luminoodle's Click light strips each feature three feet of evenly spaced light shining from 18 integrated LEDs, with a button to press to turn the lights on or off. There's 3M permanent tape on the back of the strips that allows you to easily adhere them wherever you'd like, whether that be in the garage, in your closet, behind your TV, or elsewhere in your home. AA batteries are included to power the strips, though you may want to pick some extras up for when you inevitably need to replace them. A one-year warranty is included with the set as well.
We may earn a commission for purchases using our links. Learn more.
