B&H is offering the JarvMobile 10000mAh Wireless Charging Power Bank for just $16.95 as part of its DealZone promotion. You'd usually pay in the region of $30 for this battery pack with integrated Qi charger, so you're saving $13 in this sale. The price is only good until the end of the day, so don't miss it.
The portable charger has enough capacity to charge most smartphones up to 5 times over. It has a USB-A port for hooking up your charging cables and also has a wireless charging pad built-in to the surface of the charger for powering up your Qi-enabled smartphone. Both can be used simultaneously. You can recharge the power bank itself via Micro-USB, USB-C or with your wireless Qi charger, too. There's also an LED array that lets you know the remaining battery level of the power bank.
We may earn a commission for purchases using our links. Learn more.
Samsung Galaxy Buds Pro review: The new best
Samsung's aiming squarely at the AirPods Pro with the new Galaxy Buds Pro, but it's done something better: it's made one of the best-sounding wireless earbuds you can buy.
Soundcore Liberty Air 2 Pro review: Sounds about right
Soundcore isn't a household brand just yet, but Anker's headphone division is making a name for itself as the producer of the best-sounding true wireless earbuds under $150.
Did you pre-order the Galaxy S21?
Pre-orders for the Galaxy S21 are open right now! Did you pre-order the phone already or plan on doing so soon?
Make your Chromebook more powerful with these docking stations
If you need to turn your Chromebook into an easy-to-use desktop once in a while, these docking stations are exactly what you're looking for.
