Amazon has the ILife A9 Wi-Fi robot vacuum cleaner on sale for $229.99 when you clip the $50 off on-page coupon. This robot vacuum dropped to around $280 near the end of August, but it was selling well above $400 before that. The coupon really brings it down to a low price, and we have only seen ILife offer it once before.
Suck it up
Uses maps and navigation to clean your house methodically instead of randomly. The CyclonePower tech helps make dirt disposal easier. Set up virtual barriers with the portable Electrowall device. Use the app to set cleaning modes and schedules.
$229.99 $280.00 $50 off
ILIFE A9 Robot Vacuum Cleaner
This smart robot vacuum cleaner automatically maps and navigates your home to keep it clean. Control it with the free app or even with your voice and a smart home assistant like Alexa or Google Assistant. Clip the on-page coupon to save.
ILIFE V8s Robot Vacuum Cleaner
ILIFE A4s Robot Vacuum
iLife V3s Pro slim automatic self-recharging robot vacuum cleaner
Can clean pet hair without tangling and focuses on hair, dirt, and debris on hard floors. Low profile so it can go under beds and furniture. Works best on hard wood, tile, laminate, and stone. Can be programmed. Will recharge its own battery.
Unlike some robot vacuums, the ILife A9 will not just run around randomly cleaning up your floors. It uses sophisticated mapping and navigation technology and cleans in a methodical back-and-forth pattern. It won't repeatedly go over the same spots and it won't miss areas.
Plus, the vacuum has 14 smart sensors that help it to clean along furniture and walls and climb over low piles of carpet or whatever. The vacuum is only three inches tall, too, so it can safely go underneath some pieces of furniture like your bed. The sensors keep it from falling down the stairs or getting stuck on obstacles.
You won't have a hard time cleaning out the dustbin or doing maintenance either thanks to the upgraded CyclonePower cleaning system. The technology also helps extend the life of the high-efficiency filters. The A9 is also designed to automatically return to its charging station when it's low on battery or done cleaning for the day.
The A9 comes with an Electrowall device. It's a gadget you can use to create virtual barriers for your robot vacuum. It won't cross the lines you set in place so you can keep the vacuum from going places it doesn't belong.
Download the companion app on iOS or Android. Use it to operate your new robot vacuum. Set schedules, select cleaning modes, follow the A9's progress, and more. Makes controlling your new tool a breeze.
Users give the A9 4.4 stars out of 5 based on 21 reviews.
We may earn a commission for purchases using our links. Learn more.
