OPPO is putting three 200MP cameras on its next flagship phone
OPPO Find X9 Ultra hands-on testing
(Image credit: Harish Jonnalagadda / Android Central)
  • The OPPO Find X10 Pro Max will feature three 200MP rear sensors, making it the first phone with a setup like this.
  • OPPO is once again working with Hasselblad to push the phone’s imaging capabilities further.
  • The 200MP main camera reportedly combines an f/1.5 aperture, CIPA 6.5-level stabilization, and DeepPix tech for better challenging-light performance.
OPPO's Find X10 Pro Max is set to launch in China this month, and the company has just confirmed that it’ll come with what could be the most absurd camera array we’ve ever seen on a smartphone. The headline? Not one, not two, but three 200MP sensors around the back. Yes, you read that correctly.
OPPO's Find series product lead, Zhuo Shijie, didn't mince words on Weibo either, calling this the "most powerful" (machine translated) device in its class this year. That’s a bold statement, but the hardware might actually live up to it.
Apparently, this is the world’s first triple 200MP camera system, developed in partnership with Hasselblad, again. The main shooter is rumored to use Samsung’s new ISOCELL HPC sensor (1/1.3-inch) and comes with an f/1.5 aperture, CIPA 6.5-level stabilization, and new DeepPix tech that pushes dynamic range to 17EV. This means it could handle tricky lighting much better than typical high-res sensors.
Perhaps the bigger flex here is the 200MP ultrawide. This is the first time a sensor this big has been slapped on an ultrawide. You get a 124-degree field of view and f/2.2 aperture, with OPPO claiming 102% more light captured versus the last generation.
The 200MP periscope telephoto is also no slouch, with a 70mm focal length, f/2.1 aperture, and CIPA 7.5 stabilization, which is better than the main camera. It also does a 10cm telephoto macro.
All three lenses are tipped to shoot in 8K for videos, and it’s apparently the only phone that supports full-focal-length 8K Log capture.
The OPPO Find X10 series is expected to launch with ColorOS 17 based on Android 17 around September 17. There are also rumors of a Dimensity 9600 Pro chip, a 6.78-inch 2K LTPO OLED with 144 Hz refresh, and a massive 8,000mAh battery.
Meanwhile, the standard Find X10 will presumably get dual 200MP cameras, so the Pro Max is clearly the one for photography obsessives.
Jay Bonggolto
News writer
