Best-manual-coffee-grinders-heroSource: Picjumbo
Best Manual Coffee Grinders Android Central 2021
To really enjoy a wholesome cup of coffee, it should be made from freshly ground coffee beans. The longer the beans sit out, already ground, the more the aroma escapes and the oils evaporate. The best way to experience coffee is to grind it just before brewing. Plus a little bit of elbow grease manually grinding the beans will generate a more satisfying experience. Reviewing the manual coffee grinder market, we recommend the Handground Precision Manual Coffee Grinder as our choice for the best overall manual coffee grinder. This is a ceramic burr mill type of grinder that is durable, portable, and very quiet. Prepare the best coffee with the precision settings for the coarseness you desire.
Best Overall: Handground Precision Manual Coffee Grinder
Best-manual-coffee-grinders-lifestyleSource: HandGround
The Handground Precision Manual coffee grinder is made of high-quality materials and comes with 15 adjustable grind selector settings to give precision coarseness to enthusiasts. It's suitable for Pour Over, Drip, Chemex, Cold Brew, French Press, Espresso, or any other specific brewing method you like for your java. You will get years of consistent service because of the triple mounted axle that eliminates burr wobble, so enjoy hassle-free grinding with this combination of stability and razor-thin tolerances.
The glass structure and the overall design makes this grinder an elegant item to grace any kitchen. Our only warning would be to look out for the wooden handle; it may come loose and slip out.
Pros:
  • Very quiet
  • Conical ceramic burr mill
  • Easy notch style settings
Cons:
  • Bottom sticky pads may cause damage
Best Overall
Handground-best-render-coffee-grinders-lifestyle
A ceramic burr mill precision grinder
Showcase the elegant design in your kitchen and enjoy the precision of the coffee grind.
Best Premium Level: ROK Coffee Grinder
Rok-best-manual-coffee-grinders-lifestyle-rokSource: Rok
This ROK coffee grinder has a sleek design with an aluminum finish, but it's not built for carrying around in your suitcase. The aesthetic design will definitely make a statement on your kitchen counter. The grind consistency is on par with electric grinders, and you can switch between stepped and step-less grinding by easily removing a set of washers. The handle is readily adjustable to make it suitable for left-handed use.
A non-slip ring on a strong and stable base prevents sliding or wobbling when grinding, which means you will need minimal effort to make fine grinds. The grinder is not intended to be moved around a lot from counter to counter.
Pros:
  • Aesthetically pleasing design
  • A strong base to prevent sliding
  • Little effort needed for grinding
Cons:
  • Burr gets stuck sometimes
  • Not portable
Best Premium
ROK Coffee Grinder
The showcase in the kitchen
A well designed and easy to use grinder for exacting standards and picky coffee drinkers.
Best Portable: JavaPresse Manual Coffee Grinder, Conical Burr Mill
Javapresse-best-manual-coffee-grinders-lifestyle-javapresseSource: JavaPresse
Here is a manual coffee grinder that is travel-friendly. A convenient removable hand crank makes it easy to pack away. In addition to the 18 built-in adjustable grind settings, the patented ceramic combo burrs are designed to last five times longer than stainless steel blades. The noise level is non-existent, so you can make your favorite cup anywhere, even the library! However, there are a few plastic parts in the grinder that may reduce its longevity.
Pros:
  • 18 coarseness settings
  • Travel-friendly
Cons:
  • Some plastic parts
Best Portable
Javapresse-best-manual-coffee-grinders-render
A portable coffee grinder to take anywhere
Perfect for the home and for when you're on the road.
Best Vintage Design: Hario Wood and Ceramic Coffee Mill Manual Grinder
Hario-best-manual-coffee-grinders-lifestyleSource: Hario
This is another manual coffee grinder using burrs made of ceramic, which make for a consistent grind that is easily adjustable and can be set for repeat use. Plus, you get the added benefit of a nice vintage design to augment the grinder. The wooden base and the collector drawer add a sharp look to the ensemble. However, the 10-gram capacity is a little smaller than expected, and the grinds may spill outside the drawer.
Pros:
  • Very nice classical design
  • Ceramic burrs
  • Easy to use
Cons:
  • Drawer may fill up quickly
Best Vintage Design
Hario-best-manual-coffee-grinders-render
A nice classical look
A vintage design to give you a nostalgic view into history while grinding your perfect cup o' joe.
Best Value: Hario Ceramic Skerton Pro
Harioskerton Best Manual Coffee Grinders Lifestyle TheroasterspackSource: Theroasterspack
Here is an improvement on an already excellent coffee grinder. The new elegant design of the Hario Skeleton Pro is a showcase piece for the kitchen, in addition to the improved consistency and quality of the grinds. The adjustable ceramic conical burrs shave the beans evenly, so set them at your preference and forget about it. The handle is not only detachable but also redesigned to improve the overall reliability. Even though the Hario Skerton Pro is wide enough to hold while you're grinding, the silicon base will also keep it in place as you crank the handle. Show it your friends and listen to their "jealous" comments.
Pros:
  • Consistent grinds
  • Can be used for travel
  • Nice strong grinding action
Cons:
  • Grind adjustments can take time
Best Value
Harioskerton Best Manual Coffee Grinders Render Hario
An elegant and consistent coffee grinder
A portable and compact coffee grinder that allows you to set the grind level for reuse later
Bottom line
Drinking coffee is such a personal experience that enthusiasts will spend a long time perfecting the brew to their exacting standards. The key to achieving that is the coarseness of the newly ground coffee beans. That is why we think the Handground Precision Manual Coffee Grinder is the best overall choice for manual grinding.
Not only does it look good, but the quality of the ceramic burr and the triple mounted axle will provide a consistent coarseness and service for many years. From a fine grind for espresso up to a much coarser consistency for the French press, all bases are covered with the Handground Precision coffee grinder. It also comes with a one year warranty.
Credits — The team that worked on this guide
Author: Parminder Virk
Parminder "Parmy" Virk is a freelance writer who has been writing news releases for public companies. He is a sports enthusiast and loves life.
We may earn a commission for purchases using our links. Learn more.
