Popular accessory manufacturer Anker just unveiled a whole host of new deals with prices starting at just $10 today at Amazon. This promotion includes a variety of products from Anker and its sub-brands Eufy, Soundcore, Nebula and Roav, with everything from portable chargers to truly wireless earphones, and more reduced in price for a limited time.
- Truly wireless: Soundcore Liberty Lite Earbuds
- Noise-cancelling: Soundcore Life 2 Christmas Gift Set
- Pump up the jams: Anker Soundcore 2 Portable Bluetooth Speaker
- Charge up: Anker PowerCore II 20100mAh Portable Charger
- Portable power: Anker PowerCore 10400mAh External Battery Pack
- Charge on the go: Anker PowerCore 10000 Redux
- Wireless ⚡️: Anker PowerWave 10W Fast Wireless Charging Pad
- Lay it down: Anker PowerWave 7.5W Fast Wireless Charging Pad
- Turn up the volume: Soundcore Flare Portable Wireless Speaker
- Stereo sound: Soundcore Flare Portable Wireless Speaker, 2-pack
- More outlets: Anker PowerPort Cube
- Durable cable: Anker Powerline+ USB-C to USB-A cable, 2-pack
Truly wireless headphones are taking over, and if you're not interested in spending a ton of money to try a pair out, these are the ones to get. Anker normally sells these for over $60, and this is one of the best direct price drops we've ever seen on them.
This is a new bundle that Anker's put together for the holidays, and it includes the Soundcore Life 2 over-ear headphones, a PowerCore 5000 portable battery, PowerLine+ microUSB cable, and PowerLine+ Aux cable. It also has an airplane adaptor to help you listen to music with ease during your holiday travels. Separately, these items would cost you $30 - $40 more.
This is one of Anker's most popular Bluetooth speakers. It offers 24 hours of battery life, loud, full sound, and it all fits into a super portable package. We've seen similar price drops in the past, but this $10 discount usually doesn't last long.
This is the largest capacity battery on sale right now, coming in at 20000mAh, but it also has the largest price tag. It normally sells for about $12 more, and each charge of the battery can recharge your phone or tablet up to 6 times.
With a smaller internal capacity, the PowerCore 10400 also takes up less space in your bag. This is $6 off and has two USB outputs for charging multiple devices at the same time. There are LEDs on the unit to tell you how much charge is left, so you're never left carrying around a dead battery pack.
Using Anker's exclusive PowerIQ, this can intelligently charge your device as quickly as possible without overheating or causing any harm. It offers 2 - 4 charges per recharge, and has a single USB output that you can use a cable of your choice with. It regularly sells for almost $10 more than this.
Wireless charging is the future, but it can be a bit slow. This pad offers a 10W output, which is enough to quickly charge your devices without needing you to plug them in. This is about a 50% discount, but it doesn't come with the wall charger, so you'll need to supply your own.
This charger offers a 7.5W output, which is a bit slower, but still fast enough for most devices at this point. Anker does provide a wall charger with this one, which many other companies don't do. This kit is about $10 less than it normally sells for right now.
This is one of Anker's newest speakers, and it has built-in LEDs along the bottom that can pulse as the music plays. The Christmas Edition comes with a unique box and a carrying case for the speaker, all at a discount of just over $15.
If you don't need the special packaging or carrying case, this 2-pack of Anker's Flare speakers is well worth it. You only pay about $25 more than a single speaker, but it's super useful considering you can pair them for stereo sound or just to double the volume.
This has to be one of the most portable power strips out there, and it has a truly unique design. The cube style allows for three AC outlets and three USB ports to fit into a small square package. These are great to have in your to-go bag, especially when they are $6 off.
With more devices going towards USB-C, you may be finding that you don't have enough cables around. This 2-pack of cables is tried and tested to be super durable, and right now these braided cables are nearly $4 off.
Light it up: Anker Super Bright Tactical Flashlight
If you have someone who loves to be outdoors on your shopping list, or you are one who can never find a flashlight when you need it, you'll want Anker's bright tactical flashlight. It is waterproof and drop resistant, meaning it can easily put up with the abuse you're about to put it through. It usually sells for about $7 more.
Keep track: Eufy Smart Scale C1
If your 2019 goal is to take your fitness and health a bit more serious, a smart scale is a great way to get you going in the right direction. This can track your weight, BMI, and more, and sync it with the free Eufy Life app. It regularly costs over $40, so don't miss your chance to save.
A theater in your hand: Nebula Mars
Nebula Mars is a portable cinema that weighs just over 4 pounds. It has a 3000lm LED lamp projecting 500ANSI lumens of a crisp 800p picture and can run on battery power for three hours. Cast wirelessly from your phone or connect via HDMI or USB to get all of your favorite content on the big screen. It's usually $120 more expensive.
No Bluetooth, no problem: Roav SmartCharge F3 FM transmitter
If your car stereo does not support Bluetooth, connect this to your car's cigarette lighter and pair your phone via Bluetooth. It scans for unused FM frequencies in your area, you set your radio to the same frequency, and then enjoy the tunes from your phone (that can also be charged up at the same time).
Vac vac vac it up: Eufy RoboVac 11S
If you are still vacuuming for yourself, you're doing it wrong. Correct that with the RoboVac 11S with $50 off its usual price. It can handle hard floors and carpets, avoids obstacles and stairs, and can return itself to its base when it needs to be recharged. Snap one up at its best price to date.
Most of these discounts are slated to last until December 17, as long as the stock permits. You'll want to be on the safe side here and get your orders in sooner than later so that you don't miss out. Most of these make for great holiday gifts, and at these prices you'll be able to afford to grab a variety of the items to try out.
Cyber Monday!
- The Best Cyber Monday Deals
- Find Your Cyber Monday Deal: All Deals Updated Live, Sortable By Category
- Amazon's latest Cyber Monday deal slashes Echo Dot pricing by 15% over Black Friday deal
- Best TV Deals
- Amazon Cyber Monday Deals
- Nintendo Switch Deals
- Best Phone Deals
- Best iPad Deals
- Best Chromebook Deals
- Cyber Monday Apple Watch Deals 2019
- Cyber Monday Apple AirPods Deals 2019
- Cyber Monday Apple iPad Deals 2019
- Cyber Monday VPN Deals: ExpressVPN, PIA, NordVPN, & more
We may earn a commission for purchases using our links. Learn more.
