I can’t stop customizing Insta360’s E Ink mics — the creative nametag potential is infinite
Insta360 Mic Pro mic with E Ink displays
(Image credit: Namerah Saud Fatmi / Android Central)
Insta360 is a brand better known for its lineup of rugged action cameras, but they also make other relevant equipment such as microphones. The Insta360 Mic Pro is a spectacular new wireless lavalier mic kit that has a distinctly unique feature unlike any other: E Ink displays.
Mics for Android, iOS, and cameras are probably not the first few keywords that pop in your mind when you think of E Ink displays. After all, these e-paper screens are more popular with reading tablets and digital frames. Insta360 is has actualized and unlikely convergence of the two.
Released on May 19, 2026, the Insta360 Mic Pro usually costs $329.99 for the dual mic and receiver kit, but you can get it for a $50 off right now thanks to Prime Day.
Insta360 Mic Pro
Save 15% ($50)
Insta360 Mic Pro: was $329.99 now $279.99 at Amazon
The Insta360 Mic Pro is a versatile combo mic that works with the brand's cameras, Android & iOS smartphones and tablets, as well as DSLRs and other types of cameras. Equipped with creative E Ink displays that can be fully customized, the Insta360 Mic Pro kit is worth every dime. You can score $50 off this kit while this Prime Day deal lasts!
✅Recommended if: You need a versatile mic kit that works with plenty of platforms, has a rechargeable carrying case, and has built-in E Ink displays.
❌Skip this deal if: You want mics that aren't very visible.
The Insta360 Mic Pro also comes in a singular mic kit without a receiver as well as a single mic and single transmitter kit. Since the mics can be used via Bluetooth with Android and iOS smartphones, you don't need to buy the transmitter kit if you don't plan on using the mic with a camera.
The single mic kit without a transmitter is 15% off on Amazon, going from $99.99 to $84.99. Meanwhile, the single mic and receiver kit is also 15% off, selling for $169.99 on Amazon instead of the usual $199.99.
You get a plug-and-play experience when using the Insta360 Mic Pro on smartphones
Setting up the mic is a simple matter of downloading the Insta360 app and plugging the transmitter into the USB-C port of your smartphone. After that, the mic is ready to use. The transmitter automatically connects all mics to your phone.
Once connected, you can use the app to choose any picture you like and set it as the display image for your mics. Each individual mic can have its own wallpaper. The Insta360 app allows you to resize and preview the image before confirming.
The sky is the limit when it comes to display customization
Whether its faces, brand logos, photos or captions, as long as it's an image, you can set it as the mics' wallpaper. And because the mics use E Ink panels, once the image is set, it hardly affects battery life at all!
The Insta360 Mic Pro delivers superior audio quality and comes in a carrying case with USB-C charging. The transmitter, USB-C adapter, and both mics fit inside and charge wirelessly when docked.
You get a handful of other extra accessories in the box too, including two windshields, a 3.5mm audio cable, two button magnets, two clips, a carrying pouch, and a USB-C cable. That's a lot of value for your money.
Both mics in the Insta360 Mic Pro kit feature auto gain control, 32-bit float, a 30-hour battery life, a 400m connectivity range, 3-mic array & directional pickup, and NPU-powered noise canceling thanks to dedicated AI chips.
You can customize the settings of each mic within the Insta360 app. This is where you can enable or disable auto gain control, and choose the sound direction from four options: Omni, Voice focus, Cardioid, and Figure 8.
Here are various audio samples recorded outdoors with different settings and a lot of background noise like traffic and chatter.
  • Auto gain control disabled; sound direction set to Omni
  • Auto gain control disabled; sound direction set to Voice focus
  • Auto gain control enabled; sound direction set to Omni
  • Auto gain control enabled; sound direction set to Voice focus
  • Auto gain control enabled; sound direction set to Cardioid
  • Auto gain control enabled; sound direction set to Figure 8
  • Bluetooth connection
It's an excellent kit from Insta360 that's definitely worth the spend
The Insta360 Mic Pro is a value-packed wireless lavalier kit that can adapt to whatever environment it needs to record in. You can connect as many as four mics (receivers) to the transmitter, in case you'd like to add on more individual later on.
Maybe you're combing through the market to find a fantastic microphone kit for your vlogging needs, or maybe you are a amateur videographer. Or perhaps, you're just starting out as a student in media and journalism. For all of those scenarios and more, the Insta360 Mic Pro is a high-quality starter kit that's compatible with a wide range of devices.
Namerah Saud Fatmi
Senior Editor — Accessories
Namerah enjoys geeking out over accessories, gadgets, and all sorts of smart tech. She spends her time guzzling coffee, writing, casual gaming, and cuddling with her furry best friends. Find her on Twitter @NamerahS.
