Beat the summer heat: Say goodbye to thermal throttling with these phone coolers
Torras PolarCircle Qi 2 review
(Image credit: Apoorva Bhardwaj / Android Central)
Your phone overheating is more likely to happen with the unforgiving summer heatwaves happening of late. Overheating not only slows down your phone, causing lags, but it can also potentially cause your phone's lithium ion battery to catch fire or explode in extreme scenarios.
Beat the heat and prevent thermal throttling issues on your smartphone with the right cooling accessories. Something as simple as a cooling fan or a thermal case can prevent your phone from having a meltdown — literally.
Thanks to Prime Day, you can save a lot of money on summer essentials like these phone coolers. Don't waste time making up your mind, though, because these deals end tomorrow!
Black Shark FunCooler 5
Black Shark used to be Xiaomi's gaming sub-brand. I have reviewed many of their gaming phones and accessories before and found they have incredibly good value for money. The brand's phone coolers in particular are insanely good at what they do, freezing down boiling temperatures in seconds.
The Black Shark FunCooler 5 has a cooling fan, RGB lights, and really strong 12N magnets, so you can attach it to the back of your phone magnetically. Any MagSafe, Pixelsnap, or magnetic Qi2 device should be able to use it natively. You can also use a magnetic adapter ring to make it work for non-magnetic phones.
Save 20%
Black Shark FunCooler 5: was $34.99 now $27.99 at Amazon
Cool down your overheating phone almost instantaneously and in style with the RGB-laden Black Shark FunCooler 5. Turn your hot phone into a frozen icicle with this fantastic cooler.
PHOOZY Apollo Thermal Phone Case
If you watch Shark Tank, you might have spotted the PHOOZY Apollo Thermal Phone Case on the show. This clever contraption is a thermal phone case that reflects light, deflecting heat and insulating the internals. This keeps your phone nice and cool while sealing the heat outside.
The PHOOZY Apollo Thermal Phone Case features military-grade water resistance, so it's the ideal companion for beach visits and poolside hangouts. You can choose between Gold and Silver colors, and there are two sizes: medium and large.
Save 39%
PHOOZY Apollo Thermal Phone Case: was $32.99 now $19.97 at Amazon
The PHOOZY Apollo Thermal Phone Case can accommodate any phone, no matter how big or small, and insulate it within its covers. This thermal case seals all the heat out, maintaining a cool temperature inside so your phone does not overheat, even if the weather outside is unbearably hot.
TORRAS PolarCircle Qi2 Wireless Charger
When looking to eliminate heating issues on your phone, why not get an accessory that does multiple things at once? The TORRAS PolarCircle Qi2 Wireless Charger is a 15W Qi2 wireless charger that not only cools your device using a fan, but it also recharges it wirelessly.
There's even a stand built into the back of the TORRAS PolarCircle Qi2 Wireless Charger which has a sturdy rotating a ring-like shape. And since the cooling accessory is powered by USB-C, you don't need to worry about charging it or buying a separate cable for it.
Save 20%
TORRAS PolarCircle Qi2 Wireless Charger: was $49.99 now $39.99 at Amazon
The TORRAS PolarCircle cools the center of your smartphone while recharging it wirelessly at the same time. It solves overheating issues efficiently and the handy ring-shaped stand doubles as a grip, adding maximum value and versatility to the product.
Namerah Saud Fatmi
Senior Editor — Accessories
Namerah enjoys geeking out over accessories, gadgets, and all sorts of smart tech. She spends her time guzzling coffee, writing, casual gaming, and cuddling with her furry best friends. Find her on Twitter @NamerahS.
