Update: This popular deal is back with a new coupon code. Be sure to use FPRJZNSL for the savings!
Aukey is currently offering its 3-port desktop charger for just $6 with coupon code FPRJZNSL, a savings of $9. One of the three ports is Quick Charge 2.0 compatible, allowing you to charge your device up to 75% quicker. The other two ports are just standard chargers, meaning they won't be as quick but they can all be used at the same time. This small unit is perfect carry around with you while traveling or on the go. It is a small piece that plugs into the wall and allows you to charge up to three devices at the same time.
Aukey 3 port wall charger
This deal has been popular in the past, so it may not last long. If interested, be sure to grab one soon! Remember, you need to use coupon code FPRJZNSL for the full savings.
See at Amazon
