Adding a bit of color behind your TV can work some serious magic on the overall look of the room it's in, and it can even help reduce eye strain while you binge-watch Netflix or Hulu late at night. There are a bunch of affordable options on Amazon, but one of the most dependable models is the Govee 9.8-foot LED Strip Lights kit. While it regularly sells for $15 there, you can pick one up today for only $9.79 when you use promo code 8UIEXT7T during checkout. That saves you 35% off its usual cost and brings this strip down to one of the best prices we've ever seen it reach.
New Look
Installing this 9.8-foot LED light strip behind your TV or computer desk is extremely easy, and now it's more affordable too when you use the following promo code during checkout to save 35%.
$9.79 $14.99 $5 off
At 9.8 feet long, this LED light strip kit is perfectly sized to use with a TV that has a screen size between 46 and 60 inches. It comes in four separately pieces which let you cover each side of your TV without needing to twist and turn the strip at each corner like other options require. Using the included remote, you'll be able to change the backlight's colors or brightness from up to 33 feet away, as well as change its mode, put it on a timer, or power it on and off. There are 32 different colors to switch between and six levels of brightness that let you dim or brighten the lights as needed.
This light strip even has a built-in microphone which can even sync the lights with whatever music or sound is playing in the room, allowing the lights to change colors and speed based on the rhythm.
Shipping at Amazon is free on orders totaling $25 or more, or with an Amazon Prime membership. If you've never been a member before, consider starting a free 30-day trial to score free two-day shipping with no order minimum, access to Prime Video, and more.
We may earn a commission for purchases using our links. Learn more.
