Right now you can save nearly 50% on Tacklife's Wi-Fi OBD2 scanner when you use the coupon code HMBJIMTF. It allows you to quickly read and clear engine fault codes and capture real-time data from your vehicle.
It can be used on nearly any gas-powered vehicle that was made in 1996 or later, and it works with both iOS and Android devices.
Tacklife backs this with a 24-month warranty.
