Taking advantage of vertical storage is always a good idea, and right now you can save some money while you raise your tech up. Amazon has these Wali Wall Outlet Shelves on sale for 50% off when you apply code FFY2SFYQ during checkout. You can get one for $5 or two for $10, and either way you're getting half off the normal price. Choose from White in a single pack or two-pack, or a Black two-pack. The code works on all those options.
Let Me Take A Shelfie
Keep your charging phone or smart speaker stable and elevated, and do it in the least expensive way possible.
$4.99 $9.99 50% Off
With coupon: FFY2SFYQ
These outlet shelves are super easy to use. Simply remove your existing outlet cover, pop on the new one, and voila: you have a shelf five inches deep that can hold up to ten pounds' worth of stuff. Use it to hold your smartphone, Google Home Mini, Echo Dot, Bluetooth speaker, keys, or whatever else might need some elevation. Amazon users give the Wali shelves 4.6 out of 5 stars.
We may earn a commission for purchases using our links. Learn more.
