Amazon usually sells these Govee RGB Strip Lights for $13, but for a limited time, you can enter coupon code 76Z436F3 to drop the price to just $7.79. That's a match of the lowest we've seen similar lights for this brand fall to and the best single deal on this particular iteration.
RGB
If you're in the market for bias lighting, or you want fancy rainbow colors in your closet, these strip lights are right up your alley.
$8 $13 $5 Off
With coupon: 76Z436F3
These lights have overall positive customer reviews, and they're easy to install too thanks to the included 3M adhesive and mounting clips. Once they're up and plugged in, take control with the included remote. There are 20 colors to choose from, with multiple brightness levels, and there's even a built-in music sensor so the lights can pulse to your music. This LED light strip is safe to use since it stays cool to the touch. The lights are perfect for bias lighting behind your TV or monitor, or you could also mount them on the wall, under the bed, beneath your desk, or along a windowsill.
Best VPN providers 2020: Learn about ExpressVPN, NordVPN & more
If you want more length and color options, try out these light strips instead, which fall by 26% with code UI3EF8KW. If you're in the market for more tech deals, be sure to pay attention to Prime Day next month.
We may earn a commission for purchases using our links. Learn more.
