The Aukey Quick Charge 3.0 18W USB wall charger is down to $7.92 with code 9ZMNJXPJ. The charger goes for $13 without the code and that's the price it regularly sells at. We've never seen this model drop so low before.
You can use this charger to plug directly into an outlet and charge, but you'll also need one of these if you ever want to get the most out of a wireless charger like this because these devices usually do not come with a Quick Charge wall adapter and need one for the fastest possible juice. This is a Qualcomm-certified Quick Charge 3.0 device, so any smartphone or tablet or other device compatible with that technology can use this to get super fast charging speeds. It's also backwards compatible to work with previous generations of Quick Charge, and it will charge non-QC compatible devices with standard USB power up to 2.4A. Aukey backs it up with a two-year warranty.
See on Amazon
We may earn a commission for purchases using our links. Learn more.
