The Beam Electronics universal air vent car mount smartphone holder is down to just $2.99 with code BEAMFREE. That promo code gives you free shipping, which would otherwise cost $3.99. That's more than half off what you would normally pay.
Mount and Save
The deal essentially gives you free shipping, which you would not be able to get otherwise. And the shipping costs more than the item. So you're saving a nice chunk of change.
$2.99 $7.00 $4 off
The Beam car mount is a universal smartphone holder, which means it will work with Apple, Android, and everything else. It's really simple to install because it mounts to your air vent. It's easy to use, too, with a simple release button on the back that springs open the sides and a ratchet system to help hold your phone in place. There are a ton of positive reviews for this phone, too, with more than 13,000 users giving it 4.7 stars out of 5.
We may earn a commission for purchases using our links. Learn more.
