Whether you’re illustrating logos as a graphic designer or sifting through charts as a data analyst, nothing boosts your productivity like a second monitor. However, if you need to get work done while on the go, whether at a coffee shop or on a plane, you’d be crazy to haul an entire monitor with you. That’s why Mobile Pixels has designed this portable dual monitor, which you can get for just $179.35 by using coupon code SAVEDUEXPRO at checkout.
The Mobile Pixels DUEX Pro is a portable dual-screen laptop accessory that allows you to work with two monitors anywhere and everywhere. With a second 1080p display, you’ll have more screen real estate for video editing timelines, illustrations, data analysis, and more.
Simply attach the DUEX Pro to the back of your laptop and swing the hinge out to double your screen space. The hinge rotates up to 270°, so you can extend or contract your second screen depending on how much workspace you have. You can also swing the DUEX Pro 180° away from you, which is perfect for 1-on-1 presentations or conferences.
Some jobs require multiple monitors, and with the DUEX Pro, you’ll always have a second screen on you no matter where you go. Normally $249, you can get the Mobile Pixels DUEX Pro for just $179.35 with code SAVEDUEXPRO today.
Prices subject to change
The Galaxy S20 FE is still the best Samsung phone you can buy
Samsung makes a lot of great phones, from $2,000 foldables to $200 budget options with massive batteries. These are the best Samsung phones you can buy in 2021.
LG leaving Android isn't good for anyone — except LG
At some point, throwing money into the sea will start to look like a bad idea and LG will just call it quits. I hate those kinds of days.
Hands-on: Hitman 3 for PSVR shows you can kill the old ways
Hitman comes to VR for the first time in Hitman 3 for PSVR. But this isn't just some little standalone game; it's the entirety of Hitman, Hitman 2, and Hitman 3, all playable in VR.
Here are the best screen protectors for the new Moto G Play (2021)
Even though it's a budget phone, and the least feature-rich of the new models in the Moto G line, the Motorola Moto G Play (2021) still needs protecting like any other smartphone. And that includes not only a protective case, but also a quality screen protector. Here are some great options.
