Homebrew HeroSource: Kegerator
Best Homebrew Kits Android Central 2021
When we talk about home brewing and the tools required, we're really talking about a few simple chores. We need to boil a lot of liquid. We need to transfer liquid between large containers. We need to sanitize a heap of pipes and parts. Finally, we need to store everything, first in large quantities, then in smaller bottles. Every good home brewing kit should account for these steps and nothing less. Some kits offer more control with fewer shortcuts, requiring more equipment, but basic home brewing should include a kettle, transfer tools, sanitizing gear, and bottling.
There are some brewing shortcuts that will be acceptable for your first few tries, and some that you should avoid entirely. At a minimum, beer should be made from a malt syrup and grain flavors, then fermented with yeast and allowed to age naturally to achieve flavor and bubbles. Kits that skip the flavoring steps and just have you boil a concentrated syrup, or kits that add carbonation tablets instead of allowing natural fermentation, those are kits I would avoid since they're really making boozy soda, not beer.
Best Overall: Northern Brewer Deluxe Home Brew Starter Kit
Northern Brewer Supply LifestyleSource: Northern Brewer Supply
The Northern Brewer Deluxe kit gives you enough equipment to take your first brew seriously, but not so much that you'll probably screw it up. The kit relies on malt syrup and extract, and you also get a grain bag for extra flavor, as well as nicely packed hops. You'll need to supply your own kettle (a big pot for boiling), but Northern Brewer gives you all the equipment you'll need to transfer your beer to one of the two big glass fermenter bottles provided. Having two six-gallon carboys means you can try second-stage fermenting, or you can brew a second batch to ferment at the same time.
You also get brushes and cleaning tools for all the tubes and bottles, as well as a capper and all the equipment you need for your first fill. Northern Brewer started as an enthusiast storefront in St. Paul, MN, and they brag about their seven-day customer service and support. When you are ready to graduate to more complex brewing, the company offers everything from cooling coils to grain mills and more, and your starter kit will still be a top-notch part of your process.
Pros:
  • Two glass carboy fermenter bottles
  • Simplified recipes that don't sacrifice real ingredients
  • Solid customer support
Cons:
  • No brewing kettle
  • Glass is more expensive and needs careful handling
Best Overall
Northern Brewer Supply Deluxe Kit
Just easy enough
Enthusiast-level equipment in a starter kit with recipes that give you real ingredients to brew and diverse techniques to try.
Best Value: Home Brew Ohio Gold Complete Kit
Home Brew Ohio kitSource: Amazon
If you want to spend less but still brew some serious suds, the Home Brew Ohio Gold kit gives you everything you need in a no-frills package that still offers high-quality components. You get a big plastic bucket for initial fermentation, then a glass carboy as a secondary fermenter. All of the liquid transfer (rack) equipment is there, as well as a capper to bottle your finished product. A brush and sanitizer also come with the kit.
What you don't get is a fancy recipe package with everything you need for your first brew. There are plenty of recipes available as a pack that works perfectly with this brewing kit, but don't expect the same turnkey ease you'd get with a more expensive kit. You'll also need to provide a kettle, bottles and bottle caps, and maybe a hydrometer to compute your alcohol levels.
Pros:
  • Inexpensive with quality components
  • Glass carboy second fermenter
Cons:
  • Lacks ingredients for first brew
Best Value
Home Brew Ohio kit
Quality components for a bargain
A second glass bottle with a full-featured kit is a bargain in this price range. Maybe not the easiest, but it will brew quality beverages.
Best Mash Starter: Brewer's Edge Mash and Boil with Pump
Brewers Edge Mash BoilSource: Brewer's Edge
Simpler kits will give you a malt syrup for your yeast to feast upon, but real brewing takes grain and extracts the malt sugars through a boiling process. This process is very precise and controlled, usually not something you'll find in a brewing kit. Still, the Brewer's Edge Mash and Boil give you precise temperature control and a circulating pump to keep a consistent temperature throughout the 7.5-gallon kettle. There's an adjustable run timer with a delay setting so you can get your water heated before you add your mash grains.
This is a kit meant for making wort, the liquid that is fermented to become beer, so you'll need to buy your own carboy bottles for fermenting and your own bottling system, as well as some tubes and siphons for moving the liquid around. The benefit is getting the flavor and control of an all-grain brew, instead of relying on syrups and extracts. It's more expensive, but if you want to take your brewing seriously from the very start, it's worth the price.
Pros:
  • Uses an all-grain mash instead of syrups or extract
  • Mash your wort and then boil in the same kettle
  • Controlled temperature and timer for precise brewing
Cons:
  • Only the first step of the brewing process
  • No wort chiller or fermenter included
Best Mash Starter
Brewer's Edge Mash Pump
For an authentic all-grain brew
The Mash and Boil is not a starter kit as much as an entry to all-grain brewing. Fine-tune your grain, temperature, and timing all in one pot.
Best Conical: Craft A Brew Premium Homebrew Starter
Craft A BrewSource: Craft A Brew
With most starter kits, you'll ferment your initial wort in one large vessel; then, once it has fermented and the sediment has fallen, you'll transfer the liquid to a second carboy. With the conical fermenter in the Craft A Brew kit, you don't need to transfer your brew after you move it from the kettle. The sediment falls down the cone into a jar. After the first fermentation, you remove the jar and replace it with a fresh one. The same idea makes bottling easier, as you don't need a pump and siphon to bottle.
Craft A Brew gives you a beer recipe kit with the Starter, a malt syrup kit with grains, and hops added for flavor. The company has a compelling beer lineup, including partnerships with established craft breweries Stone and SixPoint that let you brew recipes from those breweries at home. You also get a capper and caps, as well as a sanitizer, but with no tubes or siphons to worry about cleaning and sanitation should be much easier with this kit.
Pros:
  • Cool conical fermenter.
  • No need for multiple carboy bottles.
  • Fewer parts to clean.
Cons:
  • Can only brew one batch at once.
  • Expensive for a kit with fewer components
Best Conical
Craft A Brew
A unique fermenter simplifies brewing
The conical fermenter means you need less equipment to brew beer, and you can brew pub hits from Stone and SixPoint.
Best Cheap Kit: Brooklyn Brew Shop Beer Making Kit
Brooklyn Beer Shop kitSource: Brooklyn Beer Shop
If you're curious about making beer and just want to dip your toe into the carboy — maybe just to prove to yourself that it is possible to create beer in your kitchen — you could give the Beer Making Kit from Brooklyn Brew Shop a try. You get real ingredients to boil and brew, as well as a one-gallon bottle to ferment. There are several recipes to try, and each comes with its own complete bottling kit. As you'd expect from a Brooklyn shop, recipes keep up with today's trends and include a New England IPA, a Brut IPA, and beers from Mikkeller, Evil Twin, and Stillwater.
The Brooklyn Brew Shop kits use an all-grain mix, which may or may not result in better brews than more expensive kits that rely on malt syrup instead. Boiling a mash for a wort requires precision and consistency, difficult to achieve without proper equipment, but it's still cool to try real grain brewing instead of using an extract. You'll need to figure out bottling on your own, and you can only make a few gallons of beer, but for less than fifty bucks, you're getting a fun Sunday experiment that will be a fun Sunday drink a month later.
Pros:
  • Inexpensive but still uses all-grain not syrups
  • Popular breweries offer recipe kits
Cons:
  • Small batches
  • No bottling
Best Cheap Kit
A few gallons to start
Brooklyn Brew Shop sells kits that are small and cheap but don't skimp on an all-grain bill and feature popular breweries and cool styles.
Best Splurge: Clawhammer Supply Complete Homebrew Beer Brewing System
Clawhammer SupplySource: Clawhammer Supply
Clawhammer Supply started as a home distillery maker, then broke into brewing in a big way with a big all-in-one brewing system that has some innovative features you won't find on less expensive kits. The Clawhammer system is a mash and boil pot with its own pump so that you use an all-grain mix to brew. It has a few clever basket systems that let you drop in and pull out grains, hops, and other flavor additives. Because temperature and precision are so important when brewing your wort, the Clawhammer also has a neat cooler plate that pumps water through a chiller to bring the wort down in temperature quickly.
You'll need a secondary container to ferment and proceed past the boiling point. Still, if you're looking at the Clawhammer system, you probably already have a carboy and some form of bottling from your first homebrew attempts. The Clawhammer gives you much more fine-tuned temperature and timing control for more nuanced brews. The company also has an excellent reputation on social media for its videos and guides, and reviews on Amazon praise the company's support for its helpful and quick response.
Pros:
  • Advanced all-in-one system for mash and boil
  • Innovative cooling plate
Cons:
  • Still requires fermenter and bottling
  • Expensive
Best Splurge
Clawhammer Supply
Precise controls for all types of homebrewing
If you need precise heat and cooling but want to stick with a single pot, brew-in-a-bag setup, Clawhammer Supply Homebrew has you covered.
Bottom line
Homebrewing can be fun for all levels of aspiring brewers, from novices looking to make a jug of India pale ale to experts looking for a brew-in-a-bag indoor setup to brew all-grain pilsners. The system we recommend, the Northern Brewer Deluxe Starter Kit, comes with just about everything you need for a complete brew, aside from a big stockpot, which most people have. You get high-quality equipment, including two glass carboys and capping tools, to bottle your brew when you're done. The Deluxe kit should keep you satisfied while you learn how to step into the craft brew world, or it can help you upgrade from a basic plastic kit.
Once you've spent some time with the Deluxe system, you might want to step up to an all-grain brewing system like the Brewer's Edge Mash and Boil with Pump, or the mightier Clawhammer Supply Complete Homebrew. You'll be able to use the glass carboy and the equipment you already own to complete the fermenting process while building on your knowledge to make advanced recipes. The process is more complicated, starting with creating a wort from an all-grain mash instead of skipping the mash step and using a syrup. This is closer to professional brewing, though, but still convenient as a kit.
If the Northern Brewer Deluxe kit looks like too much equipment for you, consider the conical Catalyst fermenter from Craft A Brew, which lets you skip the transfer steps and perform primary and secondary fermentation in one vessel. The benefit of having two carboys with the Northern Brewer kit is that you can brew two batches in quick succession, rather than waiting for one to finish. After you've tried your own craft beer, you might want to keep a batch brewing.
We may earn a commission for purchases using our links. Learn more.
