Best Bed Frames Android Central 2021
There are several essential things to consider when buying a new bed frame. Most important of these are:
  • Space - The bed should fit comfortably in your space. A headboard will take up more space, for instance, and a small child's bedroom may need a twin rather than a full bed.
  • Style - Is your home decorated in modern, traditional, or industrial style? Is your color scheme dark or light? All of these factors will come into play when deciding on a bed frame.
  • Height - How tall should your bed be? What height feels comfortable for you?
  • Unique features - Are you looking for portability, or perhaps a lot of bells and whistles?
We'll cover all of these elements in our analysis of the best bed frames on the market, below:
Wooden Simplicity: Zinus Alexis Wood Platform Bed
Staff Pick
Of all the choices on this list, this wood platform frame was our favorite. The deep, natural wood color is a warm addition to any space, and the simple lines are both attractive and modern in style. This affordable bed stands 12in high and comes in all standard sizes.
$212 at Amazon
Best Value: Classic Brands Hercules Platform Metal Bed Frame
If you need a basic option that gets the job done, this Classic Brands Hercules Metal Bed Frame will fulfill your basic bed frame needs at a most affordable price. It stands 14in high, and you can fold it away when not in use. The platform frame comes in every size and will work with box spring as well as single mattress solutions.
$100 at Amazon
Home Life Classics Linen Sleigh Platform Bed
Traditional Sleigh Bed: Home Life Classics Linen Sleigh Platform Bed
For a classic, traditional look, the sleigh bed design is a soft, comfy addition to any bedroom. The light beige linen is understated and elegant, but the sleigh design does take up more space than the average platform bed. This particular edition only comes in king size.
$413 at Amazon
Zinus Paul platform bed
Modern Lines: Zinus Paul Metal and Wood Platform Bed
Modernism lovers rejoice! Clean lines, wood and metal materials, and a minimalist construction make this the perfect modern platform bed frame. The sleek black and wood will complement most any interior, and it comes in all standard sizes. The platform stands 14in high.
$231 at Amazon
Portable Solution: Best Choice Twin Folding Guest Bed
Here's an excellent choice for the occasional guest, or if you need a travel bed. The bed frame is foldable and portable, and it comes with its own mattress! When folded, the frame is only 10 inches wide so you can stow it away in the closet, and it has wheels! The platform stands 11" high.
$260 at Amazon
Upholstered Headboard: Zinus Lottie Upholstered Platform Bed
Attractive, sophisticated, and plushy, the Zinus Upholstered Bed Frame comes in two colors and multiple sizes to fit into your space perfectly. Elegant upholstery adds warmth and aesthetics, and the platform stands at 16 inches.
$317 at Amazon
Kid's Choice: KidKraft Addison Twin Bed
Most children's bedrooms are small compared to the master, so a twin bed is usually the best solution. The Kidkraft Addison bed has a simple yet playful design that fits into the childlike aesthetic. It is also compact and low to the ground, making it easy for kids to use.
$155 at Amazon
The Works: Reverie 9T Adjustable Bed Base
The Reverie 9T is not playing around. This luxury smart bed frame literally has it all - adjustable positions, massaging mechanisms, an LED nightlight, wireless charging pad, and zero gravity capability. This is the opposite of basic. It's the bed of the future!
$1700 at Amazon
Bottom Line
For a combination of affordability, attractive design, and clean wood lines, our favorite is the Alexis Wood Platform Bed by Zinus. The warm wood colors and simple lines make it a modern, handsome addition to any room, and since it doesn't have a headboard, it does not take up too much space.
On the other hand, if the price is a deciding factor, the Classic Brands Hercules Platform Bed has a great low price point. Finally, some people love to have all the latest features and innovative solutions. If this is the case, then you definitely want the Reverie 9T smart bed. The best options are all here; it's up to you to decide.
We may earn a commission for purchases using our links. Learn more.
