Samsung will host its next Unpacked event on February 21, which is when we'll likely see the Galaxy S7 make its debut. It looks like the manufacturer will launch the Galaxy S7 edge and the Galaxy S7 edge+ at the same time, according to an image posted by serial leaker Evan Blass.
With Samsung seeing higher-than-expected demand for the edge model last year, it is likely the vendor is looking to capitalize on the dual-curved screen option by introducing the edge+ variant at the same time. Rumors suggest that Samsung will stick to a 5.1-inch screen size for the Galaxy S7 and the S7 edge, with the S7 edge+ featuring a 5.7-inch display. This year's models are expected to feature the microSD slot and larger batteries.
Would you guys be interested in the edge+ variant if it debuted at the same time as the standard Galaxy S7?
Source: Twitter (Evan Blass)
