AT&T has begun pushing an update for Samsung Galaxy S7 and S7 edge users that brings the smartphones up to date with the latest May security patch. While AT&T doesn't yet appear to have updated its website with the details of the updates, a number of users on our forums report having received the update on both the Galaxy S7 and S7 edge.
AT&T pushes May security patch to Samsung Galaxy S7 and S7 edge
Unfortunately, it doesn't look like the update contains much else. However, it is impressive to see AT&T and Samsung issue the update so quickly after the May patch was initially released by Google.
If you haven't yet been prompted to download the update, you can manually check for it by heading the "About device" section of your Setting menu.
Thanks for the tip, LLcd PH!
