Once you've purchased a smart plug for your home, the possibilities are vast. However, you can take things one step further by picking up an outdoor smart plug too, and right now TP-Link's Kasa Smart Wi-Fi Outdoor Plug (KP400) is down to just $29.99 at Amazon when you clip the on-page coupon. This beats our previous best deal by over $7, and you'll be getting in on the best price in history for this particular pack.
Wise Choice
TP-Link Kasa Smart Wi-Fi Outdoor Plug (KP400)
This outdoor smart plug features dual outlets that can be controlled separately or as a group. You can even group them with other Kasa smart plugs in your home.
$29.99 $39.99 $10 off
TP-Link Archer A10 AC2600 MU-MIMO Wi-Fi router
This is a dual-band Wi-Fi 5 router with three external and one internal antennas. It has MU-MIMO tech for supporting dozens of devices on one network. Includes support for Amazon Alexa and IFTTT. Has four Gigabit Ethernet ports.
Kasa Smart Plug (4-pack)
TP-Link's Kasa Smart Plugs are some of the most reliable smart home devices out there, allowing you to control whatever's plugged into them using an app on your phone — or even your voice.
TP-Link Deco M9 Plus Smart Home Mesh Wi-Fi System (3-pack, Refurbished)
The TP-Link Deco M9 Plus is capable of covering up to 6,500 square feet with Wi-Fi and even features a built-in smart hub that can control ZigBee, Bluetooth, and Wi-Fi smart home products. Today you can save over 50% on the 3-pack at B&H!
TP-Link AX1800 Archer AX21 Dual-Band Wi-Fi 6 smart router
The dual-band router has faster speeds and a greater capacity than previous gens. Supports speeds up to 1.8 Gbps (1200 Mbps on 5 GHz / 574 on 2.4GHz). Easy setup with TP-Link app. Connect more devices without losing speeds.
TP-Link Archer AX1800 Wi-Fi 6 smart router
Wi-Fi 6 is the future, and the future is now. Upgrade and save money. The dual-band router has faster speeds and a greater capacity than previous gens. Supports speeds up to 1.8 Gbps (1200 Mbps on 5 GHz / 574 on 2.4GHz). Easy setup with TP-Link app.
This outdoor smart plug features dual outlets which can be controlled together or individually using an app on your smartphone. It's built to withstand harsher weather conditions, too, making it suitable for landscape or holiday lighting, swimming pool pumps, fountains, and more, thanks to its IP64 rating and an included weather-resistant cover to help when the plugs are not in use.
Using the Kasa Smart app, you'll be able to power the plug on or off from anywhere in the world, set schedules, and more. You can also group this smart plug with other Kasa smart plugs in your home so you can control them all simultaneously if you'd like. Plus, if you have a device like the Amazon Echo Dot or Google Home Mini at home, you can voice control this smart plug and even give each outlet its own name.
We may earn a commission for purchases using our links. Learn more.
