Having your monitor on a stand doesn't just give you more space to work. It can actually help enhance your focus too by keeping your workspace tidier. There are plenty of affordable options too, and this adjustable monitor stand by HUANUO becomes even more affordable when you enter promo code M6KHVFUI during checkout at Amazon, bringing its price down to $13.99. This stand normally sells for around $20 and has only fallen below $15 without a code once in the past. The height is adjustable between 2.7 and 5.6 inches, allowing you to find just the right height for your preference and desk. It's made of a sturdy MDF with plastic legs and can hold up to 22 pounds without any issues.
Desk Essentials
HUANUO adjustable monitor stand
Avoid risk of spilled drinks and other accidents with this handy adjustable stand. Using code M6KHVFUI will score you one of its lowest prices yet.
$13.99 $19.99 $6 off
Under the table, there are built-in cable management options, and on the front of it, there's a phone/tablet stand for safekeeping of your devices while you're on the computer. These monitor risers are a great way to bring your laptop up to more of a level height with your external monitors or give it some extra height if your desk sits a bit to low for it. You can easily switch between the various heights by just adding or removing blocks from the legs, and when you don't want to use it at all you can just take it off the desk without needing any tools. It's very well-reviewed at Amazon too, garnering a high rating of 4.7 out of 5 stars based on over 400 reviews.
We may earn a commission for purchases using our links. Learn more.
