Time is money, and you'd probably have more of both if you didn't have to spend all afternoon cleaning some days. With the Dser RoboGeek 20T Robot Vacuum Cleaner, you can cut down on the time and money spent by clipping the coupon on its product page at Amazon and then entering promo code DSERLIFE during checkout. Given that this robo vac is already $20 off, you're saving a total of $131 off its usual price with those coupons and snagging it for only $99.
Vac it up, vac it in
You don't have to spend a fortune to get a robotic vacuum, especially with deals like this one. Thanks to a $30 price drop, a further $50 off with the on-page coupon, and the below code, you can snag this smart home device at its best-ever price.
$91.99 $229.99 $138 off
RoboGeek 23T Smart Robotic Vacuum Cleaner
The latest RoboGeek smart robotic vacuum has a max 2200Pa suction power, a 100-minute runtime per charge, and the ability to be controlled using your smartphone or your voice. Clip the on-page coupon and use the following code at checkout to save.
Dser RoboGeek 21T Smart Robot Vacuum Cleaner
Dser's RoboGeek 21T Smart Robot Vacuum lets you use your phone to control it, or just your voice and an Alexa device. Clip its on-page coupon to score one of its best prices yet.
This robotic vacuum cleaner features a powerful 1600Pa suction and can vacuum for around 100 minutes per charge thanks to its 2600mAh internal battery. When it runs low on power, it will automatically head back to the included docking station to recharge. It has a large 600ml capacity dust collector which means you don't have to empty it all that frequently either.
Thanks to BoostGen tech, the vacuum can automatically increase suction when debris is detected and a bunch of other sensors allow it to avoid obstacles and keep it from falling down stairs. It will navigate systematically around your home to ensure it doesn't miss a spot and, thanks to its height of less than 3 inches, it can glide under furniture and catch all the dust bunnies that have been hiding. Your purchase includes two magnetic boundary strips which can be used to keep the vacuum out of select areas if you so please.
While it might not make its way onto our list of the best robot vacuum cleaners as it lacks some of the smarts like app control and voice assistant compatibility, existing owners rate it highly and at just $99 it is a super-affordable and low-risk entry point into the world of robot vacuum cleaners.
We may earn a commission for purchases using our links. Learn more.
