The satin nickel Schlage Camelot Keypad Entry Satin Nickel with Flex-Lock has dropped to $72.51 on Amazon. This keypad has been selling for between $104 and $114 for the last several months. This is the lowest price we've seen, and you'd have to go back nearly a year to find it dropping below $80 at all.
Lock Up This Price
This keypad is designed to work with any standard sized door, and it would make a great lock for a garage or home office or any other place you'd like to keep secure.
$77.30 $114.00 $37 off
The Schlage fits standard doors and is ideal for garage entry, home offices, computer rooms, and other places you'd like to keep locked up. It doesn't require special programming right away since it comes with two user codes that are preset and ready to go out of the box. With the keypad, you won't need to worry about forgetting your keys on the counter, either. The lever is also reversible so you can use it with right or left handed doors.
We may earn a commission for purchases using our links. Learn more.
