A power bank is essential in this day and age. Between Bluetooth headphones, wearables, phones, consoles, tablets, and who knows what else, it's more often the case than not that your gear may need some charging. Head to Amazon and pick up this ORICO 20000mAh Portable Power Bank for only $9.34 with coupon code 93XKN5AV. That's the best price in this item's history. It typically costs $17, and so far the customer reviews are positive.
Just Throw It In The Bag
This can fully charge modern smartphones more than four times, and it's small enough to slip into your bag with no issue.
$9.34 $16.99 $8 off
With coupon: 93XKN5AV
This power bank is capable of charging modern smartphones four or more times before needing to be recharged. There are handy LED lights to let you know how much life the bank has left, and there are two 2.4A USB-A ports so you can charge multiple devices at once. The power bank is equipped with safeguards against things like overheating and overcharging, and your purchase includes an 18-month warranty. Another thing to note is that the power bank is brown, which might seem strange at first, but it'll help you differentiate between your gear and someone else's.
Note that you'll need to supply your own charging cables. I highly recommend Anker's 3-in-1 option.
We may earn a commission for purchases using our links. Learn more.
