Updating non-smart tech is more affordable than ever. This four-pack of Teckin mini smart plug outlets is down to $25.49 on Amazon with code ZA556LYP. This pack usually costs around $30, if not more, and we never see it drop in price without a code like this one. Today's deal beats the last one we shared by $4. You'll get free shipping as well, and your items might come even faster if you use Amazon Prime.
Educate Your Estate
Teckin Mini Smart Plug (4-Pack)
You can't go wrong with four smart plugs for so little. Use a free app to power devices, set schedules, and all of that. You can control the plugs through Alexa, Google Assistant, IFTTT, and more, all without the need for a hub.
$25.49 $29.99 $5 off
Teckin Smart Dimmable Standing LED Floor Lamp
Teckin Under Cabinet Lighting 3-Pack
Teckin European Travel Plug
Instead of buying multiple adapters, save money with this 5-in-1 European travel plug. Just enter the below code to make $6 off its regular price.
Teckin Smart Plug 4-Pack
If your old tech could use an update, smart plugs are one of the easiest ways to get it done.
Teckin E27 Multicolor Smart Light Bulb 2-Pack
At just a dollar more than the best price we've seen per bulb, this is a great way to add to your smart home and save some cash while you do it.
These smart plugs can be controlled using your phone and a free app called Smart Life. You can also take over control using your voice and Google Assistant or Alexa. The plugs are compatible with IFTTT, too. Basically they're super versatile and give you tons of options once installed. Anything you plug into one of the sockets is transformed into a smart device. Set schedules, power up appliances, turn on your lights automatically after sunset, and more. You can even use the app to see if you left the lamp on after you've left. Pretty snazzy stuff here, people.
All you need to use these is a Wi-Fi network. There's no hub or anything like that required for installation. Your purchase includes lifetime technical support and a two-year warranty. Over 1,200 Amazon customers gave these plugs a total of 4.5 out of 5 stars.
Now that you have smartened up some of your old tech, it's time to check out the rest of your house. Need a smart streaming device? Smart speakers? Voice-controlled RGB lights or a smart security camera? We've got you covered with this roundup of the best smart home products under $50.
We may earn a commission for purchases using our links. Learn more.
