The Klipsch R-51PM 2-way powered Bluetooth speakers are down to $299.99 through Adorama. These same speakers are $499 at Amazon and most other retailers. That's a huge drop in price and the best we've ever seen.
Great Audio
Klipsch R-51PM 2-way powered Bluetooth speakers adorama
Upgrade from those mediocre speakers of yours to something that will blow you way and is packed with connectivity.
$299.99 $499.00 $199 off
These powered monitors have Bluetooth technology, an RCA input that can switch between line analog and a phono input for a turntable, and a 3.5mm jack. You can also connect via USB. Basically, if you have these speakers and want a way to connect to them, you will find it. The speakers use built-in 60W per channel amplifiers, and each speaker features one-inch aluminum tweeters and 5.25 inch copper-spun woofers.
We may earn a commission for purchases using our links. Learn more.
