Changing up the ambience in your home has never been easier than it is with Govee's Color Changing Light Strip Kit. This LED light strip comes with a remote control that lets you quickly change its color, brightness, and more. There are also lighting modes like Flash, Fade, and Jump to switch between. While the kit regularly sells for $36, today you can pick one up at Amazon for just $25.19 when you enter promo code ZBYOU4YN during checkout. That saves you more than $10 off its regular price there, and it also brings this kit lower than it's ever reached before.
So colorful
Govee 32.8 foot LED Strip
Whether you have a big TV you want to light the back of or a room you want some accent lighting in, this LED Strip is a perfect way to do just that. There are tons of color options built in and a remote for easy control.
$25.19 $35.99 $11 off
With coupon: ZBYOU4YN
This light strip is equipped with SMD 5050 LEDs and is capable of switching between 20 different colors using the included IR remote control. The remote works within 10 meters of the strip's control box, though if you happen to misplace the remote, the control box also allows you to change the light's color, brightness, and switch it on or off.
VPN Deals: Lifetime license for $16, monthly plans at $1 & more
Unlike many other light strips at this price, this model features an IP65 waterproof design that enables you to use it either indoors or outdoors as you see fit. It's important to note that the adapter and control box are not waterproof however, so you'll want to keep those in a dry area. The kit comes with two light strips which are each 16.4 feet long and can be cut for an adjusted length. There's an ultra-strong 3M adhesive backing on each which will let you install them easily just about anywhere. Ten support clips are included with its purchase as well.
We may earn a commission for purchases using our links. Learn more.
