The Flume smart home Wi-Fi water monitoring system is down to $159 on Amazon. The system normally sells for $199 but is down to $159 for Prime Day. It has never directly gone on sale before, either, so you're looking at an exclusive deal.
Let it Flow
You'll be able to reduce your regular water bill with this system, thus saving you even more money over time.
$159.00 $199.00 $40 off
The Flume has intelligent leak detection that can help you protect your home from water damage. It will monitor the water usage across your home, including outside sprinklers. Then it uses that data to catch costly leaks, find out where your water is going, and help you take action to conserve it. It's also easy to install and the wireless signal works up to 1,000 feet. Use the Flume app to get real-time leak detection and special notifications.
We may earn a commission for purchases using our links. Learn more.
