The Corsair iCue Commander Pro smart RGB lighting and fan speed controller is down to $39.99 on Amazon. That's $20 off its regular price and only the second time in two years it has dropped this low.
Lights Go Together
Synchronize your lights, control your fans, and monitor your system through this one powerful piece of hardware.
$39.99 $60.00 $20 off
This piece of hardware basically lets you turn your PC case into a smart case. It communicates well with iCue software and can control up to six case fans and two RGB lighting channels. There are four temperature sensors you can reposition to monitor your system. The two internal USB 2.0 headers allow you to easily connect internal USB devices, too. It can be simply and easily installed behind your motherboard or on a flat surface inside your case.
We may earn a commission for purchases using our links. Learn more.
