The Choetech wireless charging USB-C car phone mount drops down to just $19.99 when you clip the on-page coupon and enter code 5ILWMUXB during checkout at Amazon. The charger normally sells for $30 and this price beats out any previous direct price drops by a couple bucks.
Gimme the juice
CHOETECH Fast Wireless Car Charger Mount
This charger works with all phones that have Qi wireless charging built-in and is super easy to attach to your dash. Be sure to clip the on-page coupon *and* enter the below code during checkout for the full discount.
$19.99 $29.99 $10 off
With coupon: 5ILWMUXB
Choetech's mount uses a suction cup to attach to your dashboard and holds just about any phone between 2.6 and 4 inches wide. It supports Fast Charge up to 10W with recent Android phones like the Samsung Galaxy S10, 7.5W charging for the iPhone 8 or newer, and 5W for whatever's left that is also Qi-enabled. The holder is designed not to scratch your phone while still keeping it securely held, and it has a 360-degree rotating ball joint so you can find the best viewing angles while driving. It's worth noting the mount does not come with a car adapter, so you probably want to add something like this affordable dual port Quick Charge 3.0 car charger to your order if you don't already have one.
Existing owners give it 4.4 stars on average based on over 700 reviews and Choetech backs it with an 18-month warranty.
We may earn a commission for purchases using our links. Learn more.
