Got some repairs to make around the house or just looking for a new project in the new year? Maybe you're already thinking about a present for mom or dad with those respective holidays just a few months away? The Bosch CLPK22-120 12-volt cordless drill/driver and impact driver tool set drops to $84 on Amazon when you clip the $15 off on-page coupon. It's already on sale for $99 given that it regularly sells between $120 and $130, so the extra drop is just icing on the power tool cake.
Drill stuff
The set comes with a drill/driver, an impact driver, two batteries, a charger, and a carrying case for all of it. The drill/driver goes up to 1,300 RPM and the impact driver goes up to 2,600 RPM. Lightweight and works overhead or in tight spaces.
$84.00 $99.00 $15 off
Bosch 2-tool combo
Bosch 2-tool combo
Bosch GXL12V-310B22 3-Tool Combo Kit
The tool set comes with two cordless power tools, a 12-volt drill/driver and a 12-volt impact driver. It also includes two batteries, a battery charger, and a soft carrying case. The batteries work with a variety of Bosch tools, so be sure to explore other options if you're looking to round out your toolbox. The charger can get your batteries topped off in just around 30 minutes.
The drill/driver is capable of up to 1,300 RPM, and the impact driver goes up to 2,600 RPM. These are super compact and lightweight power tools, which means you can use them on overhead operations or when trying to reach in tight spaces. They have variable speeds and short head lengths, too. The drill has three integrated LED lights on the head for when you need a little extra light to see with.
The tools are backed by a three-year warranty from Bosch, too, so you can count on their durability. Just get to work and put them through the paces without worry! This tool set has a lot of positive reviews with 876 users giving it 4.7 stars out of 5.
You will get a few bits with this set as well, but if you need some more variety try picking up the Bosch 41-piece drill and drive bit set. It's going for $17.58 right now, and that's the lowest price it has been since last March.
We may earn a commission for purchases using our links. Learn more.
