Best USB-C headphone adapters 2025
Keep your wired earbuds as a spare with these USB-C headphone adapters.
While it's hard to beat the convenience of wireless earphones, there's nothing like the simplicity of using wired earphones. There's no charging hassle, and they always work as you'd expect. Most modern phones don't have a 3.5mm headphone jack anymore, but that's where the best USB-C to headphone adapters come in. This little cable converts your USB port into a headphone socket, making it easy to plug in any 3.5mm headphone or earphone.
The best USB-C headphone adapter on our extensively researched list goes to the JSAUX USB-C to 3.5mm Headphone and Charger Adapter, which allows for pass-through 60W fast charging while you're listening to your favorite tunes.
Apart from the JSAUX adapter, we've also included picks that fit not only a variety of specific tech needs, but also varying styles and budgets. Basic picks like the BENFEI USB-C to Audio Jack Adapter will surprise you, delivering top-notch quality at bottom-dollar pricing. So let's get started!
Adapt and overcome with these USB-C headphone adapters
Best overall
The JSAUX USB-C audio adapter is our best overall pick thanks to its sleek design and support for pass-through 60W PD fast charging. The aluminum housing and braided cable make it durable, and the audio jack supports mic and in-line controls for your headphones. It's compatible with a wide range of devices and is priced well.
Best budget pick
Only got $10 or less to spend? Get the fabulous BENFEI USB-C to Audio Jack Adapter with DAC chipset in the color of your choice. The nylon-braided cable is highly durable and can last over 30,000 bends. It works well with all major smartphone brands, including the Pixel 10 Pro that I tested this with.
Most stylish adapter
This sleek-looking adapter allows you to listen to music and rapidly charge your device thanks to 60W PD charging. It works with several Type-C devices, including phones and tablets from Google, Samsung, Motorola, Xiaomi, OnePlus, and other smartphones that lack a 3.5mm headphone jack.
Most compact adapter
If you want a more compact way to charge your phone and listen to your music, this is the best option for you. Simply plug it into the bottom of your phone, and then you can use the included headphone jack as well as the USB-C port as you see fit.
Best angled adapter
This tiny adapter lets you plug in your wired headphones, without getting in the way of your hands. The right-angled design sits flush against your phone, which is useful if you're holding it horizontally for watching movies or gaming. It also supports high-bitrate audio output of 24-bit/ 96kHz.
Best adapter for old Lightning headphones
If you're looking for a way to use your old Lightning headphones and accessories with USB-C devices now that even Apple has made the switch, this is the adapter you'll need. There is no software installation required. Simply plug the USB-C into your phone or computer, and then plug your Lightning cable into the other end.
Best adapter for Samsung Galaxy phones
Samsung phone owners should get this headphone adapter to connect their wired audio devices, as it's guaranteed work on any device made by the company. As a bonus, it comes with a six-month warranty, and it supports 24-bit/ 192kHz High-Res audio playback.
Best multifunctional
You kill two birds with one stone with this adapter. This USB-C adapter functions as an AUX mic jack and has a built-in DAC for stable transmission with high-res music. You don't get the highest audio support possible, but for the price, it's a good buy.
Best for sharing
Want to share audio with a friend or family member? This USB-C adapter also functions as a splitter, so you can connect two pairs of wired headphones to a single source and both listen at the same time. One person uses the master port for controlling playback and volume, and the other joins in on the fun.
The best USB-C headphone adapters for wired simplicity
Many of the best Android phones are doing away with the headphone jack, like the OnePlus 13 and Pixel 10, for instance. Even Android tablets have ditched the port. However, you can use an adapter with the USB-C port if you still want to use wired headphones. Fortunately, there are several different USB-C headphone adapters on the market from which to choose.
Consider if you want the adapter to have any other functions beyond providing just a headphone jack. If you decide you want one that features a charging port, for example, you'll need to consider whether support for standard charging is fine or you'd rather pay a bit extra for fast charging.
We highly recommend the JSAUX USB-C Headphone Adapter since it provides a 3.5mm headphone jack and a pass-through charging port supporting 60W PD fast charging. However, if you'd rather have something simpler, you'll be happy with the cheap and cheerful BENFEI USB-C to Audio Jack Adapter with DAC chipset, which only features a headphone jack and comes with a built-in DAC. Both options are super compact and won't take up a lot of space in your pocket, purse, or bag.
Last, if you're looking for an adapter that supports Lightning cables that come with wired headphones for older iPhone devices (the latest iPhones and iPads come with USB-C), you'll want to get the Anker USB-C adapter.
Namerah enjoys geeking out over accessories, gadgets, and all sorts of smart tech. She spends her time guzzling coffee, writing, casual gaming, and cuddling with her furry best friends. Find her on Twitter @NamerahS.
