Lloyd
Shop Android
T-Mobile's Android slider packs a punch
HTC MyTouch 3G Slide
The HTC MyTouch 3G Slide from T-Mobile USA is the Android smartphone that has seemed to fly under the radar.  Released at a time when Snapdragon processors and AMOLED screens are all the rage, the mid-range specs on the Slide disguise the performance and feel of this qwerty slider.  Packing its own flavor of the touted HTC Sense UI and running Android 2.1, the Slide was a phone I was itching to get my hands on and put it through the paces.  Hit the jump to see my impressions of this solid, but forgotten phone.
The packaging
We'll spare you the unboxing, as we've seen about as many of those as we can take :) .  The packaging does deserve a little look however.
MyTouch 3G Slide packaging  MyTouch 3G Slide package opened
You won't find the normal everyday cardboard and paper box.  The Slide comes in a hard shell plastic case, reminiscent of a small jewelery box.  Inside you'll find everything in its own padded compartment, where it fits nicely safe and sound.  Speaking of everything, included are a microUSB cable and an AC-to-USB charging block, the various manuals and "getting started" guide, and an above-average quality headset with inline remote, earbuds and a shirt clip.  A part of me thinks having this sort of packaging is a really nice touch, while the other part realizes that you'll probably just end up putting it in a drawer, not to be seen for the life of the phone.  In any case, it's different.  And in today's competitive market, different is good as long as it's done well -- and in this case (pun intended!) it is.
The exterior hardware
The Slide is mid-range in size as well.  It's 4.5 inches tall, 2.4 inches wide, and 0.6 inches thick.  It's relatively slim even though it packs a four-row horizontal sliding qwerty keyboard, and it feels good in the hand.  With the keyboard closed, it feels very much like one of the previous generation (G2) HTC devices.  The similarities end there though, as we'll see as we go through things.
MyTouch 3G Slide front view    MyTouch 3G slide front opened
Up front, you have a capacitive touchscreen (3.4 inches at 320 x 480 resolution), four physical buttons -- Home, Menu, Back, and the Genius Button in place of the expected Search button (You can check out how it performs here, where we put it head to head against Vlingo), and a trackpad that also acts as an action button.  Up top you have an attractive chrome earpiece, a light sensor and an LED for notifications.  Slide it open, and you have the four-row keyboard, which we'll get into later.
MyTouch 3G Slide top down  MyTouch 3G Slide - bottom view
MyTouch 3G Slide top -- opened  MyTouch 3G slide bottom - opened
On top you have the power button and a 3.5 mm headphone jack.  On the bottom, there's the standard microUSB connector and two microphone grills -- not that there's dual mics on the phone itself, but there are two openings to help things from being muffled by cases or fingers.  I found the microphone preformed just fine, callers said that I sounded normal during usage.  Around back you find the 5-megapixel camera, with LED flash and the speaker grill.  In my opinion, the speaker on the phone is excellent, both for media and when using as a speakerphone.
The internals
I've been playing with a souped-up Froyo ROM on my N1 for a while, and I was sure the transition to using the Slide was going to be painful at best.  I was pleasantly surprised when I found out how wrong I was.  The Slide is a snappy device, both on paper during benchmarking and in real-world use.  It certainly won't be breaking any land-speed records, but it's more than able and holds its own against some of the other newer offerings in the Android world.  It does all this with a 600 MHz Qualcomm ARM 11 processor, and a respectable 512 MB of ROM and RAM.  Very nice to see that HTC and T-Mobile didn't hold back in the memory department.  The battery is a 1300 mAh Li-Ion, and I have zero complaints about battery life -- even with poor signal I was easily able to get a full day's use of e-mail, messaging and talk.
Speaking of benchmarking, have a look and see how the MyTouch 3G Slide fares against it's bigger, faster cousins the HTC Evo 4G and the Nexus One
YouTube link
The inevitable comparisons
Because it's an Android horizontal slider, it's going to be compared to the Motorola Droid. And because it's an HTC horizontal slider, it's going to be compared to Windows Mobile-powered HTC Touch Pro 2.  Neither comparison is fair, and the MyTouch 3G Slide stands well on its own. But for the sake of completeness, have a peep.
Slide and Droid 1  Slide and Droid 2
Slide and TP2  Slide and TP2 2
The Slide's keyboard falls right in the middle here.  The layout, button spacing, and lack of a horribly placed D-Pad makes the Slide's keyboard better and easier to use than the Droid's.  The Touch Pro 2's fifth row -- and the simple fact that the Alt. characters are screened in a different color -- make it better and easier to use than the Slide's keyboard.  Having said that, the sliding mechanism is fine, and you'll find yourself quickly getting used to using it with decent speed and accuracy, so forget how it compares to other qwerty sliders and give it time to grow on you.
The software
The Slide runs HTC Sense 2.1 -- but with a twist.  Commonly known as Espresso, it's unique to the Slide and includes a horizontal homescreen.  All the standard Sense features you know and love are there, as well as a few Slide specifics.  Have a look at the walkthrough below where I go over some of the differences and similarities.
YouTube link
As you can see, things are mostly what we're used to in the software on other HTC Sense devices, like the Incredible or the Hero or the Desire.  T-Mobile has added and changed a few things, mostly for the better.
  • T-Mobile's App pack -- a set of applications suggested by T-Mobile, and an easy way to browse them.
  • T-Mobile's My Account -- an application that lets you view your current T-Mo account settings.
  • T-Mobile Visual Voice Mail -- A visual voicemail app specifically for T-Mobile customers.
  • My Device -- contains the User Guide, and settings for things like ringtones, wallpaper, mobile networks, screen settings, etc.
  • MyFaves -- An interface (complete with widgets) to your T-Mobile myFaves.
  • MyModes -- A MyTouch 3G exclusive that allows themeing of the Sense Espresso UI.
  • MyTouch Music -- A T-Mobile supplied streaming music application.
  • The Genius Button -- T-Mobile's answer to voice commands and search.
  • IM -- The HTC Instant Messenger client.
  • Swype -- The fabulous keyboard replacement.  The Slide gets its own version, and it works identical to the standard.
  • Barcode Scanner -- The Slide includes the popular application, available for everyone else from the Android Market.
While nobody here is happy to see carriers make changes to default software, in this case it's not that bad.  None of the apps are too invasive, and a few are even handy programs you would want anyway.
The Camera
The Slide comes with a 5-megapixel fixed-focus camera, with software zoom and effects -- i.e. the same camera software in every other Sense UI phone, which isn't a bad thing.  You won't be replacing even the most basic point and shoot with the Slide, but it's fine if you think of it as just a cellphone camera.  Stills turned out fair, even in my less-than-capable hands.  Here's a sample (in order) of a pair of inside shots under a 4 foot flouro light, a pair of outside shots, and a pair of zoomed in shots. They're full resolution, so mobile viewers beware.  Pardon my messy office -- visitors usually don't get to see the basement :)
One messy office  sleepy kitty
weiner dogs  backyard
sattelite dish  tree leaves
The same things apply to the video capture.  Quick videos grabbed in VGA resolution are acceptable from a cellphone, but don't toss out your HD camera, or even your Flip.
 YouTube link
Final thoughts and impressions
The Slide is first and foremost a phone and communication device, and it does an excellent job at both.  Call quality was fine on both ends, the speakerphone performed well, louder and clearer than any other Android phone I've used, which is quite a few.  Wireless and GPS were both rock solid, and it handles all my e-mail and messaging needs with no issues.  Bluetooth performance is as good as any newer HTC device -- not perfect, but good enough in most cases.  Battery life was great with no tweaking, easily making it through a full day right out of the box.
On the multimedia side, the Slide performs much better that expected.  The 3D gaming experience is on par with any of the new Snapdragon phones, albeit at a much lower resolution and screen size.  Music sounds decent from the unit's speaker, and the included headset is as good or better than most mid-range stereo earbuds I've used in the past, including some very well known brands.  Video playback was great, no stutters or pixelation from streaming video or playing movies from the SD card.
There are a few things that could be better.  The phone's plastic body is pretty "creaky."  Both closed and with the keyboard extended the phone just doesn't feel as solid in the hand as I'd like.  Removing and replacing the battery door is a nuisance, and you get the feeling that if you had to do it often you'd soon be replacing it.  There's also the (non)issue of the screen size.  Not too long ago a 3.4-inch screen would have been big, but today it's the bare minimum.  For me, it's a decent trade for being more pocketable and feeling better against my head on a call, but it's something you need to decide for yourself.
The MyTouch 3G Slide is certainly something you should consider, especially if the 1GHz, big screen phones don't tickle your fancy.  The form factor is great, the size is perfect as a phone, and it performs well against the new breed of superphone.  I wouldn't have anything to complain about if I were to use this as my daily driver.
14 Comments
Posted by willquil1
July 12, 2010 - 09:271 year ago
Doesn't do it for me. Ill be waiting on the Epic regardless. Good for T-Mobile customers though
Posted by PopsGG
July 12, 2010 - 10:441 year ago
Great review. Phone seems ok, but its not for me.
p.s. A few of your photos came out dark. Not the photos with the phone, but the photos of the phone.
Posted by selenitic
July 12, 2010 - 11:021 year ago
I got this phone for my wife and its been really good so far. The only complaints that she has are UI related. There are couple of issues with text messaging where the messages jump around or sometimes are out of order if she she is sending a message at the same time that she receives one.
Also the contact list is little bit of a mess since it imports from both google and t-mobile contacts. You can not remove the t-mobile contact syncing and sometimes it creates duplicate contacts.
If this fix these software issues the phone would be perfect for everyday android users since it is really fast.
Posted by angermeans
July 12, 2010 - 14:131 year ago
Great review Jerry, seems to be a great entry level Android phone. The more Android phones that get out there will bring more and more great devs and we all can benefit from that.
Posted by PantsOnFire
July 12, 2010 - 15:191 year ago
How about that "Genius" button? Did you test the usability/functionality of that?
Note: My apologies if it was covered in the video, the video would not load for me, either embedded or on Youtube's site. :/
Posted by exiii
July 12, 2010 - 16:101 year ago
I have this phone. Got it on Father's Day. It is my first Android device, but I've been using Google web apps, including Voice and Sync, for a very long time though. I got the phone, logged in, and it was good to go with my full contact list & calendar.
@PopsGG: I'm not totally sold on all the contact syncing. The good thing though, is that you can link up contacts so they only show up as one contact. But sometimes you'll still have the same number under one contact several times. Some pruning was required, and I often prefer my photo choice for someone over their facebook pic.
Overall, I think the slide is a good midpoint between device size and screen size. I've never been a fan of big phones (just switched from a BB Pearl). But big screens are great to look at. This one feels wide, but good in my hand. I definitely don't want anything bigger.
The Genius button: IMHO it's too slow to use. There is a long wait from when you push the button to when it's ready to listen. I'd rather it recorded right away, then set up the connection and process the input. Some may disagree though. I avoid it most of the time, but there are definitely times when voice recognition is nice.
The camera is good enough to use for documenting job sites, which I do frequently. The external speaker is great. Nice loud turn-by-turn directions.
I just want the T-Mobile Faves to go away. I'd love to put something else there (calendar, sms or a user-defined option).
Swype works great ... if I can look at the screen. Even open, I still can't type on this phone without looking at it. My BB was great at touch-typing. This one just isn't.
Posted by apollostees
July 13, 2010 - 05:021 year ago
Got this phone for my wife and she loves it. As stated this is not a super phone nor does it pretend to be. But, for a good entry/mid-level phone you can't beat the MT3GS.
My only complaint is HTC's sense UI. It's not to bad really. But, I personally prefer stock Android and I wish they gave you the option of turning of sense. Other than that this is a great phone.
Posted by ImTheDuke
July 13, 2010 - 13:551 year ago
Sorry. First reply was to the wrong post. Meant the one below :)
Posted by MudDog
July 13, 2010 - 10:331 year ago
Finally, instructions on how to use the Genius Button:
http://tmobile.dragonmobileapps.com./demo.html
Posted by ImTheDuke
July 13, 2010 - 13:531 year ago
That looks pretty good. I noticed on the voice commands he was putting the handset up to his mouth. I'm wondering if it would still work as well while sitting on a car center console so you could be totally hands free. Not a concern for me because I have blue tooth in my car with Ford Sync. Thinking of getting this for my wife and her car does not.
Posted by KingGrimlock
July 13, 2010 - 10:461 year ago
i don't like the icons they've used. it's like touchscreen for dummies: "touch here and here, but not here -- that's for the other icon, silly."
and i don't like the placement of the spacebar on the virtual keyboard.
however, i like the idea of "personalized" themes.
Posted by experiment626
July 13, 2010 - 10:561 year ago
Not in the same class as the Moto X, Evo,or Incredible but still a nice mid-range device.But any review that features Weiner Dogs is a winner in my book.
July 14, 2010 - 23:271 year ago
Well, I think this is just as good as it is. I actually like HTC. good gadgets
Posted by unclethursday
July 19, 2010 - 11:141 year ago
As I've said before, I really think T-Mobile will push this phone towards the SideKick users. Mid-range, not overly expensive, does everything the SideKick did and more.
For people who would have gone for the SideKick, I think this is a good alternative choice (teens, early 20's).
