Best small wireless chargers for earbuds & smartwatches 2022
By Christine Persaud , Courtney Lynch published
Charging your true wireless earbuds usually involves placing them inside their included charging case, but how do you charge the case itself? Usually, it's via microUSB or USB-C cable, but wireless charging is often another option. As for charging your Android smartwatch, some models can be charged wirelessly. It's easy to place your wireless earbuds or smartwatch atop the charging surface, and you'll be ready to charge without wires. We've rounded up some of the best small wireless chargers for earbuds and smartwatches.
Ventev Wireless Charger Qi Chargepad+
This small, circular-shaped wireless charger offers rapid charging for most Qi-enabled devices. Place your wireless earbuds or smartwatch in the center, and it will charge up in no time. You'll love the stylish design that allows you to place it anywhere in the home, and it won't stick out like a sore thumb. It's MFi certified to work with Apple (7.5W) and Samsung (10W) devices. One of the best features is the extra-long 5-foot charging cable that allows you to place it anywhere and tuck the cord out of sight.
Belkin Boost Up Wireless Charger 10W
Optimized for Qi devices, this charger can charge at 5W of power for devices like true wireless earbuds, including the Apple AirPods 2, or 7.5W for the iPhone and 9W for Samsung devices. With a 4-foot cable included along with a two-year warranty, you can grab the wireless stand as well for charging smartphones upright. It's a great option for charging both phones and earbuds that will adjust the wattage based on the device placed atop it. It comes in black or white.
Anker Wireless Charger PowerWave Pad
With this wireless charger, you can check the charging status with the LED indicator. If it's flashing blue, an object might be in the way of successful charging. If it flashes green, you might not be using a compatible 5V/2A or higher adapter. A solid blue light means your device is actively charging. You get a 4-foot cable, 10W max charging power, and cool color options such as black, white, and navy. There are multi-pack options, too.
Spigen SteadiBoost Compact Wireless Charger
Super compact, this wireless charger can fit in the palm of your hand and can easily be tucked away on your office desk, nightstand, or even in your backpack or purse. It is Qi-certified and supports up to 10W charging, ideal for both smartwatches and wireless earbuds. The charger itself charges via USB-C and has useful Control Heat Technology that helps prevent overheating.
Samsung Duo Pad Wireless Charger
Using this convenient wireless charger, you can charge your wireless earbuds and smartwatch at the same time! It also offers Fast Charge technology for Samsung Galaxy smartphones, which means Galaxy S10 and newer devices can charge up to 12W. Most people buy this for their phone and watch, but keep in mind that it's Qi-certified to charge any Qi-enabled device. It comes with a one-year warranty, too.
OIUSHYO 3-in-1 Wireless Charging Station
Perhaps you need to be able to charge all of your devices at once, including your smartphone, smartwatch, and wireless earbuds. If that's the case, the OIUSHYO 3-in-1 wireless charging station will fit the bill. It's relatively compact and won't take up too much space. It even comes with an 8W quick charge 3.0 wall plug. You'll enjoy over-current protection, over-voltage protection, and over-temperature protection for a safe charging experience.
Best small wireless chargers for earbuds and smartwatches: Make a choice
If you want to cut the cords and be able to plop your wireless earbuds case or smartwatch down on a wireless charging surface, there are plenty of options. Out of all the best small wireless chargers for earbuds and smartwatches, our favorite is the Ventev Wireless Charger Qi Chargepad+. First and foremost, it has an attractive design that makes it a versatile choice for placement anywhere in the home. Not to mention that you get a super-long cord that can be easily tucked away out of sight.
If you want to charge two devices simultaneously, the official Samsung Duo Pad Wireless Charger is the better way to go. It's especially a good option if you own a Samsung Galaxy smartphone and Galaxy earbuds since it can fast charge the phone. It might be the most expensive, but it's the most reliable and efficient option for Samsung users.
When you're seeking a wireless charger that allows you to be truly unstoppable, look no further than the OIUSHYO 3-in-1 Wireless Charging Station. Reduce the number of chargers and cables on your nightstand or workspace. This charger makes it possible to charge your earbuds, smartwatch, and smartphone simultaneously. It offers wide compatibility for numerous devices, including iPhones, Apple Airpods, Samsung Galaxy phones, and Samsung smartwatches.
Courtney Lynch is a freelance writer at Android Central. She's obsessed with all things health, fitness, and music. At any given time, she can be found checking out the latest and greatest gadgets while simultaneously petting her dog and sipping iced coffee.
Get the best of Android Central in in your inbox, every day!
Thank you for signing up to Android Central. You will receive a verification email shortly.
There was a problem. Please refresh the page and try again.
