Motorola Charm
The Motorola Charm is the embodiment of the "smart-messaging phone."  It runs Android, but make no mistake -- it's not what you would expect from your typical Android phone.  It has an excellent qwerty keyboard, a small screen well designed for messaging applications (but little else), and a price point that makes sense.  Hit the break to see my impressions of Android's version of the Kin.
When I first got the Charm, I took a quick look at the hardware.  That's a great place to start.
YouTube link for mobile viewing
The Charm is built well, and its primary function (in theory anyway) as a phone is great.  It has dual microphones for noise canceling, call quality on both the earpiece and speakerphone is excellent, and Blur's dialer is easy to use and very intuitive.  Overall, you would be very pleased with the fit and finish.  The touchscreen, while small and permanently stuck in landscape mode, is responsive, and the 600 MHz OMAP processor is more than enough to power the Charm for the things it can do.  Here are the full specs:
  • Android 2.1 with MOTOBLUR UI
  • 600MHz OMAP processor
  • 2.8-inch 320 x 240 pixel Gorilla Glass touchscreen display, multitouch support
  • Physical and virtual QWERTY keyboards
  • BACKTRACK navigation pad on rear of device opposite display
  • Quad-band GSM/GPRS/EDGE, dual-band WCDMA (1700/2100)
  • CrystalTalk PLUS noise reduction technology
  • 3-megapixel fixed-focus camera, digital zoom, video capture (24 fps)
  • Wi-Fi (802.11b/g/n), Bluetooth 2.0 + EDR, USB 2.0 connectivity
  • GPS
  • 3.5mm headphone jack
  • MicroSDHC support up to 32GB
  • Accelerometer, light sensor, proximity sensor
  • 1170 mAh battery, 300 minutes talk time, 334 hours standby (3G)
  • Size: 67.2 x 98.4 x 11.4 mm
  • Weight: 110 grams
Charm -- front Charm in hand
Charm -- bottom Charm -- top
Qwerty keyboard Charm -- USB port
Trackpad
Its size is a bit odd, being rather short and wide,.  We can look at the specs and know exactly how it measures out, but I'm a visual guy, so here are a few pictures to give you an idea.
Length measurment Charm width measurment
Charm and Evo
One last bit of the hardware we need to look at, and that's the battery.  Or batteries, because the T-Mobile version of the Charm I'm reviewing comes with two, as well as an extended battery door to cover it up.  It's a good move, as the stock 1170 mAh battery doesn't cut the mustard, and the 1370 mAh barely gets me through a day's use.  Mind you, I'm an email machine, and it's not unheard of for 500-plus email messages to go in and out of my Gmail in a  day.  I call that the BlackBerry curse.  Anyhoo, the extended battery and cover looks just fine on the phone, and the little bit of thickness actually helps me type on the qwerty a bit better.  YMMV.  Look below to see the difference between the battery doors, and a comparison of the batteries.
Stock batery door Extended battery door
Battery comparison
The software
Here's the fun part.  The Charm runs Blur.  Full-on, love-it-or-hate-it Motoblur atop Android 2.1.  Oddly enough, if you keep in mind that the Charm is a smarter messaging phone, Blur works well.  And because of the screen size, orientation, and resolution, you're not going to be playing games or watching full length videos on the thing, so I'm not going to hate on it too much.  Blur gives you access to every kind of messaging service known to modern man, it's integrated into everything, and keeps you in touch.  Honestly, heavy social media users would love it if they can get over the stigma that goes along with the Blur name.
But not all of Blur works well on the Charm.  The screen size and poor resolution makes most of the widgets downright useless (the settings widgets being the exceptions), and if you're like me you'll end up with a mess of empty homescreens, and some shortcut icons filling the void.  The widgets are fully resizable, just like every other iteration of Blur out there, but the tiny screen just doesn't let it work.  Here are a few snaps of just what Blur on the Charm looks like.
Huge widget Big widget
resizing the widgets small widget
As I said earlier, the dialer and contacts work really well, without being overly complicated.  Just don't expect a lot of eye candy.
Blur contacts dialer
Blur accounts
Multimedia options out of the box are pretty sparse, but you'll probably be able to fix that via the Android Market.  The Charm does come with a local and streaming music player, with ShoutCast built in, as well as an FM tuner.
Shoutcast playlist Shoutcast player
FM tuner Gallery
The Charm's camera is a non-feature.  It's a fixed focus (no barcode scanner for you!) 3 MP shooter that's perfect for taking snaps of friends passed out to text to other friends, but not much more.  Motorola did include Kodak's enhancement feature which helps, but don't go into it thinking this will replace any camera.  The video camera is even worse.  CIF resolution (maximum) combined with mediocre hardware just doesn't cut it.  We saw the same outcome with the Motorola i1's video camera, and like then I'm not going to waste the bandwidth to even show an example.  Just pull any dumbphone out of your desk drawer, shoot a few seconds of video and that's what you get.  I hope this isn't a trend, as tweens and messaging junkies deserve better.  Here's a few stills, at full resolution and untouched to judge for yourself.
Close up, indoors Macro, indoors
Bright lighting, indoors Halloween decor
motion shot Busy colors
It does pretty well with motion, see the waving flag, but lots of colors seem to really mess with either the CCD chip or the software.  I tried about 25 different shots of the stained glass lantern against the cherry tree, and that was the best of the lot.  Of course, YMMV.
A final rant about software.  I'm not very pleased that I'm required to download Windows drivers to do something as simple as charging the battery via USB on the Charm.  Motorola, you can do better. We know you can do better.
We've talked about the good and the bad, but what's my final verdict on the Charm?  That depends on what you need it for.  Don't go into it thinking you'll take advantage of the thousands of apps on the Android Market, because the phone wasn't designed for that.  On the other hand, this is the phone your teenage daughter wants.  It's perfect for keeping in touch, and because it is running Android the benefits of Google's services put it a huge step above your run-of-the-mill texting phones.  The keyboard is great, dare I say on par with my old favorite the BlackBerry 8830, and as many of you know that's saying a lot.  The phone runs well (better than I expected actually), and Blur isn't the dealbreaker on this one that it may be on Motorola's powerhouse phones like the X or the Droid 2.  As long as you go in knowing what you need, and what to expect, the Charm could very well be for you.
There are 20 comments
Jonneh says:
Thanks for this review Jerry. :)
I take it the Flipout will be pretty similar.
JeffDenver says:
Meh
icebike says:
So it looks like a texting phone for junior high school kids.
eahinrichsen says:
That's exactly what it is. A phone for people who don't need professional features and who mostly use their smartphones for Facebook and Twitter and such. It obviously won't catch on with the traveling business crowd, but the market for a well-built, functional social media phone is a heck of a profitable niche.
icebike says:
If done right, it could be profitable.
But Don't tell that to Microsoft.
Remember the Kin? It failed out of the box.
Isn't the screen permanently stuck in portrait mode? Or am I missing something -- perhaps the screen is wider than it is tall?
757EliasHZ says:
I love my Charm. It was the phone that finally took me away from Blackberry (I have to have portrait keyboards). This was a good review; as I am very happy with it in part because I use my phone for messaging the most. That said, because of the odd orientation and the resolution many of the apps for Android aren't even available.
Exactly! For anyone who doesn't need BlackBerry Email, this is the best messaging phone out there. Enjoy the hell out of it.
EdgeOfMonkey says:
I will sell you my prototype I had to test for $1! The phone is cheap and quite awful. I am much liking my current prototype phone.
Jonneh says:
I'll take it!
serpico says:
As I said before, my wife got this phone from the Telus carrier up here on day one. There is a WIFI bug that kills the stock battery in less than 12 hours. It's greatly reported in the motorola forums. She doesn't use wifi during the day so I turned it off and selected the battery saver profile and it now lasts a full day for her. Hopefully motorola gives out a firmware update at least since I don't think Froyo will ever come to this device but you never know.
It's a nice phone not only for the social kids but for people who need the keyboard and are not heavy users like most of us with high end smartphones. I don't like the resolution of the screen but my wife came from an old Curve with low res so she is fine. I showed her the Droid Pro that was shown yesterday and she wants it now! So I don't think the Charm will be around for long as soon as Motorola starts selling the new phone!
Shadnic says:
I'm surprised by how snappy that little thing is. The form factor is very nice...a blackberry alternative for android. I can see this being great for people who mostly use their phones for email/texting, and don't plan on downloading hundreds of apps. If I wasn't such an app-hound, didn't care for gaming, and if this was a bit more high-end, then I'd honestly be a little bit interested.
kubernetes says:
The form factor looks pretty nice, like an old-school Blackberry.
If it had good exchange support it could be fantastic. Just don't get a voice plan and use it purely for messaging.
dwt10 says:
its is not the android version of the kin, rename that first paragraph. It doesnt have a 5MP camera, its not a slider, it has a tiny screen. its more like a mini android blackberry.
Mano123 says:
Too old school, why would people want to go backwards instead of forwards? Almost all the phones motorola is shitting out have 3mp cameras . Am I the only one who think they are throwing out too many phones at once that there support can't handle? XD at least there not on 1.5 or 1.6 lol
p4trickh#IM says:
Can we please get Jerry a nice pair of white Mickey Mouse like gloves? That finger is getting better, but he's still no where near ready for being a hand model.
Jonneh says:
Although I find your comment humorous, don't you think it's a little creepy that you pay so much attention to his hands? I mean, is it one of those "once seen it cannot be unseen" ordeals or something? I've seen his hands but I never see what you guys always are whining about. I find it pretty simple to just focus on the phone, you know, the thing I am interested in (not some man's hands and whether they are unkempt or beautiful)...
Nirvana328 says:
maybe he's into hands or something...not that there's anything wrong with that ;)
pili#ac says:
Hi everyone, Im so happy cuz tomorrow i will be having my motorola phone, I think that is a really good one, what can you tell me about some kinds of troubles in it or something like that ?
Thank you for helping :) lol
pili#ac says:
