One of Amazon's deals of the day includes two Ecovacs Deebot robot vacuum cleaners down to super low prices. The Deboot 500 is down to $169.99. This robot vacuum normally sells for a street price around $270. We have never seen a direct price drop this low.
The Deebot 711 is also on sale but for $269.99. It is more expensive, but this model is more advanced, and the regular price is around $530. So you're actually saving even more with this deal.
As an extra incentive, Amazon is throwing in a free Echo Dot with either model. Considering both robot vacuums have smart functionality and can be controlled via your voice through the Alexa voice assistant, the Echo Dot is a perfect add-on to go with your new gadget.
VPN Deals: Lifetime license for $16, monthly plans at $1 & more
Free Echo Dot
Ecovacs Deebot 500 and 711 robot vacuum cleaners with Echo Dot
Save $140 on the Deebot 500 and $295 on the Deebot 711. Both robot vacuums have a ton of smart features, including the ability to map a room without getting stuck. They have app control for setting schedules and voice control, which works with Alexa.
$169.99 $310.00 $140 off
The Deebot 500 uses two side brushes and a main brush to sweep, lift, and vacuum up all the dirt around your home. It has multiple settings you can use to decide how it cleans including Auto Mode, which will clean an entire floor, Spot Mode for a small area, and Edge Mode for those pesky edges and corners. You can use the free app to directly control the vacuum, check status updates, and make schedules for when it should and should not clean. The Deebot 500 also has a Max Mode Power to increase the suction and clean messier spills.
If you decide to upgrade to the Deebot 711 you'll be getting all that and a little more. For example, the 711 has Smart Navi 2.0, which lets it actually map your home while it cleans. It can use this information to create the perfect cleaning path, so it never cleans the same place twice. It also lasts long enough to clean up to 1,100 square feet per cycle. You will still be able to control and schedule it via the free app.
Obviously if you're buying this on Amazon and getting a free Echo Dot with it, you're probably going to be inclined to order the robot vacuum around using Alexa. But it's worth noting that both versions are also compatible with Google Assistant.
If you think this deal is good, you should check out everything going on for Black Friday this week. We're already seeing some pretty spectacular savings.
We may earn a commission for purchases using our links. Learn more.
