The blue Xcentz 10000mAh portable charger is down to $17.99 with code XCENTZS95 on Amazon. The battery pack normally sells for around $32 and doesn't drop from that price without unique codes like this. This deal price only works on the blue version as sandstone black is still selling for the $32 street price.
More Power
Xcentz 10000mAh 18W Power Delivery Quick Charge 3.0 USB-C portable charger
If your compact battery charger is only going to have one port, it should be a port that does a whole lot. This one uses Quick Charge 3.0 and 18W Power Delivery to give you the fastest possible charge on any device.
$17.99 $32.00 $14 off
With coupon: XCENTZS95
This power bank is meant to be super compact. It is smaller than a credit card and super lightweight. You'll be able to carry it with you, whether that means storing it in a backpack or just putting it in your pocket. That makes it super easy to top off your phone while you're sitting on the subway. Or maybe you can use it to charge your device in a discrete way while sitting in class or a meeting.
VPN Deals: Lifetime license for $16, monthly plans at $1 & more
The single USB-C port can recharge all your gear and has 18W Power Delivery. The USB-A port on the other side has Quick Charge 3.0 technology. It can fully charge an iPhone XR in less than two hours using Fast Charge. The power bank will last you a long time, too, as the battery has been tested to endure more than 5,000 recharges.
The 10000mAh battery capacity gives you a lot of juice in a small device. You'll get several full recharges before you ever have to connect to an outlet. Users give it 4.4 stars based on 30 reviews.
Take advantage of the USB-C Power Delivery speeds with the right cables. Grab an Anker USB-C to Lightning cable for your iPhone devices or a USB-C to USB-C cable for your Android phones.
You'll also want a USB-C wall charger to fully take advantage of Power Delivery and recharge the device as fast as possible. The wall charger needs to be at least 12W for the fastest recharge, so grab Anker's 15W USB-C charger for just $13.99.
We may earn a commission for purchases using our links. Learn more.
