Amazon usually sells this NURSAL White Noise Machine for around $18.99, but today you can enter coupon code O7OLS48L during checkout to drop your cost to only $10.82. Shipping is free with Amazon Prime or on orders of $25 or more. This is the best deal we've seen yet for this machine, which has very positive reviews so far.
YOU'RE GETTING VERY SLEEEEPY
Drown out the silence with this inexpensive machine. Fall asleep faster and stay asleep throughout the night.
$12.34 $18.99 $7 off
With coupon: O7OLS48L
Whether you're dealing with constant insomnia or you work third shift, sometimes it can be hard to shut your brain off and fall asleep at night. A white noise machine helps calm everything down so you can catch some zzz's without tossing and turning for hours beforehand. This machine has 24 different sounds, which is a way bigger selection than similar models we've shared. That means if babbling brooks don't do it for you, there are plenty of other options to choose from, and it'll also help you avoid getting used to one particular sound.
VPN Deals: Lifetime license for $16, monthly plans at $1 & more
There are timer and memory functions, too, which allow you to fall asleep without worrying about wasted energy throughout the night. The machine is compact and easy to travel with, and it can be powered by batteries or via USB. Note that you'll have to provide either a wall adapter or four AA batteries to power the machine. The fact that it can run on batteries is a nice touch, since it allows you to take the machine camping or to a hotel room without too much trouble. Your purchase includes a one-year warranty.
We may earn a commission for purchases using our links. Learn more.
