Trying to prioritize all of your devices when choosing between two AC outlets can be difficult. Solve the problem for good with this Bestek Power Strip, which usually costs $27. Today you can score yours for $19.99 thanks to coupon code BYVSYTTU at Amazon. This is the best deal we've seen since October, and there's no telling when it'll drop back down in price again.
Square Up
Bestek Power Strip
Manage all of your tech, no matter what kind of cables you're using.
$20 $27 $7 Off
With coupon: BYVSYTTU
This one tiny gadget saves you tons of space, thanks to its three AC ports, two USB-A ports, and single USB-C port. There are options on three sides of the cube for easy rearranging should you need it, and the LED power switch lets you see what's going on. The cube itself is even mountable, either via screws or adhesive, so you could place it permanently under your desk for everyday convenience. Your gear will stay protected thanks to the built-in safeguards against overcharging, short circuiting, and other similar situations. Amazon users rate it with 4.3 out of 5 stars.
We may earn a commission for purchases using our links. Learn more.
