Getting your house kitted out with smart home tech doesn't have to cost a fortune. One super easy and affordable way to get some smart lighting set up is to install a Wi-Fi-connected light switch rather than buying individual smart bulbs. That way, you can add some smarts to your whole room with one purchase. Right now, you can pick up a Treatlife Wi-Fi Smart Light Switch for just $12.99 at Amazon when you clip the on-page coupon and enter code 8N5VVMFQ during checkout. That code drops the switch lower than we've ever seen before.
Affordable smarts
Treatlife Smart Wi-Fi Light Switch
This inexpensive switch plays well with Alexa, Google Assistant, and IFTTT. You can get it at a $7 discount when you clip the on-page coupon and then enter the below code during checkout.
$12.99 $19.99 $7 off
This requires a neutral wire, but installation is easy thanks to the included step-by-step instructions. The smart switch gives you voice control over the lights in your home when you use it with an Alexa or Google Assistant device. There's a remote control included, too. Use your smartphone to create schedules, control the lights, monitor real-time status, and more. That's perfect for times where you're at work wondering if you left the light on. Treatlife includes a two-year warranty with your purchase as well as lifetime customer support.
Treat yo self
Treatlife Smart Wi-Fi Light Switch 2-Pack
These smart switches are really easy to install and cost only $12 apiece when you clip the on-page coupon for 10% off and then enter the below code during checkout. We've never seen them go this low before.
$24.69 $37.99 $13 off
If you'd like you can also save on the 2-pack for $24.69 with its on-page coupon and the same promo code at checkout. That's also an all-time low price, dropping the individual price of each switch to just over $12. If you're shopping for more smart home gear on a budget, check out our list of the best smart home products under $100 for more ways to smarten up your appliances without breaking the bank.
We may earn a commission for purchases using our links. Learn more.
