Best security cameras that work with Amazon Alexa 2025
Security cameras that work with Amazon Alexa provide immense convenience for automating home activities. Imagine being able to sound off commands like "Alexa, lock up for the night" or "Alexa, show me the feed from the front door," directly from your couch or bed. This way, you don't have to dig into your phone app each time you want to perform any basic activity with your cameras.
Among the many Alexa-enabled security cameras, the Arlo Pro 5S 2K really stands out. It has strong Alexa integration and comes with a good set of features like 12x zoom and HDR video. Here are all the best security cameras that work with Amazon Alexa. Amazon's Big Spring Sale is live, so keep an eye out for good savings.
Check out these awesome security camera deals
The best security solutions for your smart home
The best Alexa devices combine excellent features with ease of use and convenience. For a great Alexa-compatible security camera, you really can't go wrong with the Arlo Pro 5S 2K. Though it is on the expensive side, with its excellent feature set, and solid Alexa integration, it is a winner.
Latest Videos From
If you're looking to complement your Ring Video Doorbell, then you'd do well to pick up the Ring Spotlight Cam Plus Wired. The Ring Protect plans are inexpensive, and they come with other awesome features, like Ring Neighborhoods, which send you real-time crime and safety alerts from other Ring users in your area. Plus, you'll have all of your smart security taken care of in one app.
Blink makes some excellent cameras, and its upgraded Outdoor 4 is a great choice if you need a wide field of view and dual-zone motion alerts. For the best flexibility, it's hard to beat the range of motion of the Wyze Cam Pan v3. For its relatively affordable price, you get 360 degree horizontal motion and 180 degree vertical, thus eliminating most blind spots with just a single camera.
Olivia Lipski is a freelance writer for Android Central and loves testing out the latest smart home tech and discovering the best cell phone plans. When she's not busy running around NYC trying to find great food or coffee, she's in her kitchen trying to make it herself.
With contributions from
