Best Nest Hello covers and wall plates 2022
By Christine Persaud , Mick Symons published
The Nest Hello doorbell, one of the best Ring video doorbell alternatives, is your window to the outside world (you know, aside from the actual windows on your home). That means it's actually outside all the time. It's a good idea to protect it or, at the very least, cover it so that it won't get weather-worn and scuffed. These are the best Nest Hello covers and wall plates for the popular video doorbell.
Elago silicone Google Nest Hello case
These silicone cases are UV-resistant and come in six colors to add a bit of pizzazz to an otherwise boring-looking device. Elago's cases will protect your doorbell from the elements, and it won't block the camera, microphone, or any other necessary components.
Elago Wall Plate
Elago's wall plates are a great backdrop to your Nest Hello. They come in four colors and are UV-resistant, double-coated for extra weather resistance, and they help to cover up any marks or holes behind your Nest Hello.
kwmobile Protective Silicone Cover
Along with a durable skin that protects the camera from the elements, this one also has a built-in sun shield that helps to prevent glare from the sun. This, in turn, gives you clearer footage on sunny summer days.
POPMAS Adjustable Angle Mount
With a total of 120 degrees of rotation, including 60 degrees either left or right, you can get the perfect view from your Nest Hello camera. Made of sturdy and durable metal, the wall plate also comes with an easy installation kit and detailed installation instructions.
Koroao wall mount
If the only place you can put your Nest Hello is less than ideal or you want tilt functionality, this is the wall mount you want. It helps to prominently display your doorbell, having it sit out from the wall, with the ability to turn 35 degrees left and right. For a better field of view, grab this mount.
Fintie Silicone Case
Fintie makes excellent silicone cases, for both phones and the Nest Hello. This cover is durable, has all the proper cutouts for the microphone and camera, and a little baseball-cap-style brim that should help to keep rain off the camera lens. Five colors are available.
Bottom line
The Nest Hello is by no means ugly, but covering it up isn't just about hiding it. You can also protect it from the elements. When it comes to the best Nest Hello covers, Elago's cases are the best option on this list because they offer durable protection, come in some lovely colors, and are rather inexpensive. Elago's covers are also well-rated, and their products, in general, are well-rated all over Amazon, which indicates that its products are high-quality and well-liked.
If you want a better field-of-view or at least more viewing options, the POPMAS Adjustable Angle Mount is your best option. That 60 degrees makes all the difference if you don't have an optimal spot to place your doorbell. This mount also installs fairly easily, and it has enough space to make wire placement hassle-free.
For the ultimate protection in very sunny locales, you might want to opt for the kwmobile Protective Silicone Cover, which has a built-in sun shield to prevent sun glare so you get clearer footage.
Get the best of Android Central in in your inbox, every day!
Thank you for signing up to Android Central. You will receive a verification email shortly.
There was a problem. Please refresh the page and try again.
