Arguably one of the most annoying parts of owning a smart phone is having to plug it in to charge it, and then unplug it to use it, and then plug it back in to charge it again. This is especially true if you use the device a lot, and the charging port of your device is located in an inconvenient place, which many of them have started to move to. LG Mobile has announced a new wireless charging system that they plan to use, which will allow users to place their device on the charging slab, and charge there device without needing to plug it in.
The battery doors will have special coils built in and contacts on it as well that will allow the charging to take place, and the mat will have multiple colored LED's that will help easily determine where in the charging phase the units are. Hit the break for more information about this new wireless charging solution from LG Mobile.
LG MOBILE PHONES INTRODUCES REVOLUTIONARY WIRELESS CHARGING SOLUTION LG Wireless Charging Pad Features Industry Leading Charging Efficiency |
LG MOBILE PHONES INTRODUCES REVOLUTIONARY WIRELESS CHARGING SOLUTION LG Wireless Charging Pad Features Industry Leading Charging Efficiency SEOUL, Mar. 22, 2011 -- LG Electronics (LG) announced today the LG Wireless Charging Pad (WCP-700). Featuring a sleek and sharp design, LG Wireless Charging Pad is poised to revolutionize wireless charging as we know it. With inductive coils built into the battery doors and internal contacts, advanced wireless charging technology allows for a cord-free power source - alleviating the need for external connections that limit the phones usability. LG Wireless Charging Pad provides industry leading wireless charging and ergonomics. For easy and intuitive use, LG Wireless Charging Pad features audible and tactile feedback when a phone is placed on the pad, as well as multi-colored LED lights to indicate charging status. Taking the hassle out of charging your wireless devices, LG Wireless Charging Pad also sports a compact, sleek design to easily accommodate an on-the-go lifestyle. Key Features: - Visual, audible and tactile feedback – allows user to see, feel and hear when the phone is placed properly on the pad * Power LED - Blue = Plugged in * Battery LED - Orange = Ready to Charge * Battery LED - Flashing Green = Phone is Charging Correctly * Battery LED - Solid Green = Phone is Fully Charged - Slim and sleek design – allows for convenient storage, taking up minimal space - Effective Range – 7mm from center of placement guide - Dimensions – 6.29”x3.54”x0.39” | |
949(forum posts)
